    trouble with homing the x and y axes on a core xy printer.
    1.8k
    • Vetiundefined
      Veti
      @campeancalin said in trouble with homing the x and y axes on a core xy printer.:
      G91 /G1 H2 X10 F3000"
      if this moves only in the X direction, then you do not have a corexy machine
      and decided to go further with the attempt to home the xy gantry to no avail
      what do you mean by that? there was no movement?
      the homing code does the same thing as your manual move in the first command.
      please post the output of m122
      campeancalinundefined 1 Reply Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt
        In you config.g file you have this:
        G31 P500 X10 Y10 Z3.5 ; set Z probe trigger value, offset and trigger height
        As I recall for a BLTouch P500 should be P25
        And are you sure those X10 and Y10 offset values are correct?
        I designed my own hotend mount and the closest I could position the BLTouch was X0 Y25.
        Also for testing you can use M564 to allow using the DWC jog buttons before homing as been done.
        The possible parameters to M564 are H and/or S (see below):
        H1 = forbid movement of axes that have not been homed, H0 = allow movement of axes that have not been homed
        S1 = limit movement within axis boundaries, S0 = allow movement outside boundaries
        So issuing M564 H0 would allow using the jog buttons, M564 H1 would restore things to normal.
        • campeancalinundefined
          campeancalin @Veti
          @Veti said in trouble with homing the x and y axes on a core xy printer.:
          m122
          Bellow you have the M122 result:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-917NK-F23T0-6JKFG-3S46S-1HAJF
          Used output buffers: 3 of 24 (9 max)
          Static ram: 25680
          Dynamic ram: 94376 of which 188 recycled
          Exception stack ram used: 320
          Never used ram: 10508
          Tasks: NETWORK(ready,652) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3748) IDLE(ready,160)
          Owned mutexes:
          Last reset 00:03:17 ago, cause: power up
          Last software reset at 2020-10-05 16:45, reason: User, spinning module GCodes, available RAM 10480 bytes (slot 3)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 25.7, current 32.5, max 32.5
          Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 5: standstill, SG min/max not available
          Driver 6: standstill, SG min/max not available
          Driver 7: standstill, SG min/max not available
          Date/time: 2020-10-05 19:51:00
          Cache data hit count 763106029
          Slowest loop: 2.24ms; fastest: 0.07ms
          Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === DDARing ===
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 41.62ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is running
          WiFi firmware version 1.23
          WiFi MAC address ec:fa:bc:02:17:e5
          WiFi Vcc 3.42, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 25448
          WiFi IP address 192.168.0.100
          WiFi signal strength -61dBm, reconnections 0, sleep mode modem
          Edit: formatting
          • Vetiundefined
            Veti
            there is your problem. you are not on RRF3.1.1 as you have written
            campeancalinundefined 1 Reply Last reply Reply Quote 1
              campeancalin @Veti
              ok, I might have confused it with the config tool version.
                campeancalin @fcwilt
                @fcwilt do these commands work if the version of the firmware is 2.03?
                Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                • Vetiundefined
                  Veti @campeancalin
                  @campeancalin
                  your config file does not work with RRF2
                    campeancalin @Veti
                    @Veti Can you be a bit more specific?
                    • Vetiundefined
                      Veti @campeancalin
                      @campeancalin
                      the pin configuration syntax only works in rrf3
                      • fcwiltundefined
                        fcwilt @campeancalin
                        Yes they do.
                        But a set of files generated for v3 firmware will not work with v2 firmware without some changes.
                        I would go ahead and update the firmware to v3.
                        First update using Duet2and3Firmware-3.0.zip.
                        When asked allow it to update.
                        Then update using Duet2and3Firmware-3.1.1.zip
                        You can upload each ZIP file on the System page.
                          Once you update to 3.1.1 your current config has a better chance of working.
                          You should probably redo the motor direction tests for corexy after you update.
                          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                            campeancalin
                            Thank you kindly. I was not aware of these differences
                              Since you're starting from scratch it doesn't much matter, but here are the details.
                              https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                                campeancalin
                                Hello guys,
                                Thank you again for the heads up regarding the differencies between the machine config and the firmware that was on the board.
                                Today I went on and upgraded the firmware on the board, and reuploaded the machine config. At a first glance, the xy gantry seems to move in the right direction ; I still cant perform the homing on them. I also moved the z axis, on which I have 2 in series motors ( ZA and ZB are being used to control them), and while the z axis is performing the required movement , the E0 extruder motor is also moving.
                                Bellow you can see the M122 report:
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
                                Used output buffers: 3 of 24 (11 max)
                                Static ram: 27980
                                Dynamic ram: 94972 of which 20 recycled
                                Exception stack ram used: 408
                                Never used ram: 7692
                                Tasks: NETWORK(ready,292) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 00:10:43 ago, cause: software
                                Last software reset at 2020-10-06 17:51, reason: User, spinning module GCodes, available RAM 7700 bytes (slot 1)
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 32.7, current 33.3, max 34.0
                                Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 2: standstill, SG min/max 0/260
                                Driver 3: standstill, SG min/max 0/51
                                Date/time: 2020-10-06 18:02:09
                                Cache data hit count 1128396488
                                Slowest loop: 6.69ms; fastest: 0.12ms
                                === Storage ===
                                SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 314759ms
                                === MainDDARing ===
                                Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                                === AuxDDARing ===
                                Segments left: 0
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                === Network ===
                                Slowest loop: 39.91ms; fastest: 0.00ms
                                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                - WiFi -
                                Network state is active
                                WiFi Vcc 3.42, reset reason Unknown
                                WiFi flash size 4194304, free heap 25336
                                WiFi signal strength -65dBm, reconnections 0, sleep mode modem
                                === DueX ===
                                Read count 1, 0.09 reads/min
                                Also, the config file is detailed bellow . There might be several issues in it , but as a first step I need to take care of the movements and the homing issues.
                                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 05 2020 11:50:08 GMT+0300 (Eastern European Summer Time)
                                G90                                                ; send absolute coordinates...
                                M83                                                ; ...but relative extruder moves
                                M550 P"Oscar"                                      ; set printer name
                                M669 K1                                            ; select CoreXY mode
                                M551 P""                                           ; set password
                                M552 S1                                            ; enable network
                                M586 P0 S1                                         ; enable HTTP
                                M586 P1 S1                                         ; enable FTP
                                M586 P2 S0                                         ; disable Telnet
                                M584 X1 Y0 Z2:3 E4:5                               ; set drive mapping; INIT:X=0; Y=1; Z2;E3:4
                                M569 P0 S0                                         ; physical drive 0 goes backwards
                                M569 P1 S0                                         ; physical drive 1 goes backwards
                                M569 P2 S1                                         ; physical drive 2 goes FORWARDS
                                M569 P3 S1                                         ; physical drive 3 goes FORWARDS
                                M569 P4 S0                                         ; physical drive 4 goes backwards
                                M569 P5 S0                                         ; physical drive 5 goes backwards
                                M350 X16 Y16 Z16:16 E16:16 I1                     	   ; configure microstepping with interpolation ; INIT- M350 X16 Y16 Z16 E16:16 I1
                                M92 X160.00 Y160.00 Z3200.00:3200.00 E420.00:420.00        ; set steps per mm
                                M566 X900.00 Y900.00 Z12.00:12.00 E120.00:120.00           ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z180.00:180.00 E1200.00:1200.00     ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z20.00:20.00 E250.00:250.00           ; set accelerations (mm/s^2)
                                M906 X1400 Y1400 Z1200:1200 E800:800 I80                   ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                                    ; Set idle timeout
                                M208 X0 Y0 Z0 S1                                   ; set axis minima
                                M208 X500 Y500 Z500 S0                             ; set axis maxima
                                M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                                M950 S0 C"duex.e5heat"                             ; create servo pin 0 for BLTouch
                                M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
                                M557 X15:470 Y15:470 S20                           ; define mesh grid
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                                M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                                M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                            ; map heated bed to heater 0
                                M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                                M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                                M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                                M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e1temp
                                M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
                                M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                                M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                                M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                                M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                                M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
                                M563 P0 S"Tool 1" D0 H1 F0                         ; define tool 0
                                G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                                G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                                M563 P1 S"Tool 2" D1 H2 F0                         ; define tool 1
                                G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
                                G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                                M575 P1 S1 B57600                                  ; enable support for PanelDue
                                M501                                               ; load saved parameters from non-volatile memory
                                Edit: formatting
                                • Vetiundefined
                                  Veti
                                  this does not match your config
                                  Za and Zb are both driver 2
                                    campeancalin @Veti
                                    @Veti Thank you
                                      campeancalin
                                      The motors work fine, I still cant home the x and y
                                      • Vetiundefined
                                        Veti
                                        can you describe in detail what happens when you press homex
                                          campeancalin @Veti
                                          @Veti both motors receive current but the gantry does not move.
                                            campeancalin
                                            the x motor has an atempt to make a move , but to no avail.
