    Core XY - Y Homing not functioning correctly
    Firmware installation
    723
      Please post your entire config.g and the results of M122.
      Since this is a new build it would be a good time to go with RRF3. The syntax of your homey would indicate that it's for RRF2. (uses S1/S2 instead of H1/H2)
      What firmware do you have installed?
      • Vetiundefined
        Veti
        @wharris87 said in Core XY - Y Homing not functioning correctly:
        After the Y axis has 'homed' DWC gives the y position as '350.00', even though it hasnt even moved towards the end switch, let alone touched it!
        use M119 to verify your endstop configuration
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
        press it by hand and issue the command and see if the status changes.
        • wharris87undefined
          wharris87
          thanks for you replies - I have just updated firmware to 3.0
          M122 Result;
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917NK-F2MS4-7J1F8-3SD6N-KHT8F
          Used output buffers: 3 of 24 (6 max)
          Static ram: 30516
          Dynamic ram: 91624 of which 152 recycled
          Exception stack ram used: 224
          Never used ram: 8556
          Tasks: NETWORK(ready,756) HEAT(blocked,1340) MAIN(running,3740) IDLE(ready,156)
          Owned mutexes:
          Last reset 00:00:16 ago, cause: software
          Last software reset at 2020-10-09 08:39, reason: User, spinning module GCodes, available RAM 8164 bytes (slot 2)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
          Error status: 0
          Free file entries: 10
          MCU temperature: min 29.5, current 29.8, max 30.3
          Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-10-09 08:39:36
          Cache data hit count 33674276
          Slowest loop: 1.58ms; fastest: 0.09ms
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 13.96ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.21
            WiFi MAC address 84:0d:8e:b3:b4:98
            WiFi Vcc 3.40, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 16040
            WiFi IP address 192.168.1.170
            WiFi signal strength -64dBm, reconnections 0, sleep mode modem
          M119 results (x and y switches physically 'open');
          M119
          Endstops - X: not stopped, Y: at max stop, Z: at min stop, Z probe: at min stop
          M119 Results (x and y both physically 'closed');
          M119
          Endstops - X: at min stop, Y: at max stop, Z: at min stop, Z probe: at min stop
          config.g;
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 09 2020 08:35:11 GMT+0100 (British Summer Time)
          M550 P"BLV mgn Cube" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X160.00 Y160.00 Z400.00 E418.00 ; set steps per mm
          M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X350 Y350 Z350 S0 ; set axis maxima
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:285 Y15:285 S20 ; define mesh grid
          M143 H0 S100 ; set temperature limit for heater 0 to 100C
          M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
            jay_s_uk
            The status of the y endstop is not changing when being pressed or not.
            This suggests a wiring issue.
            Time to break out your multimeter and get testing
            wharris87undefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              please now update to 3.1.1
                wharris87 @jay_s_uk
                @jay_s_uk love a big of rewiring! but would this explain how/why the indicator light on the board changes when the switch is pressed/depressed?
                  jay_s_uk @wharris87
                  @wharris87 no, it would not, so theres definitely something dodgy going on.
                  Is it plugged into the correct port?
                    wharris87 @jay_s_uk
                    @jay_s_uk im assuming the light wouldnt be coming on if it was plugged into the wrong port?
                      jay_s_uk
                      The lights function regardless of whether the endstop is configured in firmware or not.
                      maybe a photo would help?
                        wharris87
                        To quote my initial post... 'its either the board, or im being really stupid'.
                        It was the latter; i had the y stop plugged into the 'E0 Stop' port, which meant 'a' light was switching on/off, but it was the wrong one!; helps if i read the very helpful text etched onto the board!!
                        Thanks for your help everyone!
                        jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                          jay_s_uk @wharris87
                          @wharris87 Glad you got it sorted!
