    Error: M587: string too long
    Firmware installation
    • tkdirpundefined
      tkdirp
      ls /dev/tty.*
      screen /dev/tty.usbmodem14201 115200
      M552 S-1
      M552 S0
      M588 S"*"
      M587 S"KT_GiGA_5G_C403” P”def30hx181”
      M552 S1
        droftarts administrators @tkdirp
        @tkdirp Use straight quotes for commands. You have:
        should be
        M587 S"KT_GiGA_5G_C403" P"def30hx181"
        Also, on Mac, using the Terminal for this is painful. I've recently found SerialTools, free on App Store, works well: https://apps.apple.com/gb/app/serialtools/id611021963?mt=12
        • tkdirpundefined
          tkdirp
            @tkdirp is KT_GiGA_5G_C403 a 5GHz network? Duet 2 Wifi can only connect to 2.4GHz.
            • tkdirpundefined
              tkdirp
              Oh, okay thanks
              • tkdirpundefined
                tkdirp
                @droftarts
                is it a wifi problem or the Duet problem?
                  Can you try setting up the Duet in Access Point mode? This will have the Duet create its own wifi network that you can connect to from your device. If this works then we know the problem is with the router/configuration rather than the duet hardware.
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
