    New firmware 1.19 beta 2
    Firmware installation
    18
    70
    10.0k
    • Sniffleundefined
      Sniffle
      DC42, with the current 1.19Beta3, are the flashing instructions still the same as with the previous 1.19 versions that require the firmware and wifi to be updated simultaneously?
      • Bobblejotundefined
        Bobblejot
        Hi dc42, nothing is pressing against the erase or reset ports like i said i always put down the ajax errors and odd firmware resets down to the firmware but over the months and update after update nothing has ever improved, it just seems to get worse. And as an early purchaser number 62 i think i never expected things to be perfect, but some stability would have been nice, the 2 Duet 0.8.5 i have i haven't updated in a long long time but work fine ( well except one with a fan issue but its fine ).
          So is the main problems that the port reverts to the Bossac port, which will have the side effect of making it impossible to connect with the board over WiFi? If so then I'm happy to authorise a replacement board, because that should not be happening. However, if this mostly occurs when the printer has not been used for a while and you live in a country with high humidity, then this problem might be caused by condensation, and I may be able to suggest a modification you could try.
            @Sniffle:
            Yes if you are upgrading from firmware 1.19alpha or earlier. If you are already running 1.19beta 1 or 2 then you just need to update the main firmware.
            • StevenLundefined
              StevenL
              I upgraded to 1.19beta3. Now it does not connect over a web connection. In fact it does not advertise its web service at all.
              (I'm an IT guy…)
              Do I need to revert to the 1.18 i was running or is there a way to correct this? How would I roll it back to the previous firmwares?
                You need to set up access to your router different!y. There is a link to the instructions in the upgrade notes, but here it is for your convenience: https://duet3d.com/wiki/DuetWiFiFirmware_1.19_alpha.
                • robmundefined
                  robm
                  @dc42:
                  I'm not having any problems ('over the moon' is best description of my new DuetWifi experience!) - but I do live in such a country. Interested in any suggestions for ensuring the long term health of the system in such an environment?
                    Bobblejot
                    Hi dc42, i actually live in Scotland so humidity isn't really an issue. The ajax errors have always been there but its the number of times that i need to re-flash the firmware that is starting to really frustrate. I can do a print and everything is perfect then go to do another and have no access to the web interface.
                      Please ask your supplier to replace the board. I think the microcontroller chip is faulty, it doesn't seem to be holding the state of the "Boot from flash" flag.
                        Bobblejot
                        Hi dc42 thanks for that, the board actually came direct from yourselves.
                          T3P3Tony administrators
                          Please send us an email and we will sort it!
                            Bobblejot
                            Hi Tony just emailed you.
                            • vhowardundefined
                              vhoward
                              Well. Just tried the new beta4. Still no joy. Won't connect. Really looking forward to an ethernet module.
                              • minimundefined
                                minim
                                Have anyone that had crashes with alpa and beta1/2 tested the most recent ones? Any crashes?
                                • BlackTomundefined
                                  BlackTom
                                  David,
                                  I've flashed beta 4 yesterday on my corexy and the board is resetting by itself without any known reason.
                                  Yesterday the printer reseted during a print that was running for less than 5 minutes and this morning I was running my bed compensation macro and it crashed again.
                                  this is the m122 output.
                                  M122
                                  Used output buffers: 3 of 32 (5 max)
                                  RepRapFirmware for Duet WiFi version 1.19beta4 running on Duet WiFi 1.0
                                  Board ID: 08DAM-999TL-NL5T8-6J1DA-3SJ6P-T55BJ
                                  Static ram used: 20356
                                  Dynamic ram used: 95876
                                  Recycled dynamic ram: 2552
                                  Stack ram used: 1304 current, 3804 maximum
                                  Never used ram: 8484
                                  Last reset 00:00:13 ago, cause: software
                                  Last software reset reason: User, spinning module Network, available RAM 8484 bytes (slot 4)
                                  Software reset code 0x5001, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0040080f, BFAR 0xe000ed38, SP 0xffffffff
                                  Error status: 0
                                  Free file entries: 10
                                  SD card longest block write time: 0.0ms
                                  MCU temperature: min -270.2, current 16.4, max 16.7
                                  Supply voltage: min 11.2, current 11.4, max 11.7, under voltage events: 0, over voltage events: 0
                                  Driver 0: stalled standstill
                                  Driver 1: stalled standstill
                                  Driver 2: stalled standstill
                                  Driver 3: stalled standstill
                                  Driver 4: standstill
                                  Date/time: 2017-06-03 09:17:31
                                  Slowest main loop (seconds): 0.004786; fastest: 0.000030
                                  MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
                                  Bed compensation in use: mesh
                                  Probe change coordinates:
                                  Bed heater = 0, chamber heater = -1
                                  Heater 1 is on, I-accum = 0.0
                                  Segments left: 0
                                  Movement lock held by null
                                  http is idle in state(s) 0
                                  telnet is idle in state(s) 0
                                  file is idle in state(s) 0
                                  serial is idle in state(s) 0
                                  aux is idle in state(s) 0
                                  daemon is idle in state(s) 0
                                  queue is idle in state(s) 0
                                  Code queue is empty.
                                  Network state is running
                                  WiFi firmware version 1.19-beta1
                                  WiFi MAC address 5c:cf:7f:1b:3c:b8
                                  WiFi Vcc 3.11, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 39864
                                  WiFi IP address 192.168.1.101
                                  WiFi signal strength -63db
                                  HTTP sessions: 1 of 8
                                  Socket states: 2 0 0 0 0 0 0 0
                                  Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  • BlackTomundefined
                                    BlackTom
                                    I ran the macro again and this time it failed just after its completion.
                                    M122
                                    Used output buffers: 3 of 32 (6 max)
                                    Last software reset reason: User, spinning module Network, available RAM 7824 bytes (slot 0)
                                    Software reset code 0x5001, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0xffffffff
                                    Error status: 0
                                    MCU temperature: min -270.2, current 16.6, max 17.1
                                    Supply voltage: min 11.2, current 11.6, max 11.7, under voltage events: 0, over voltage events: 0
                                    Date/time: 2017-06-03 09:31:52
                                    Slowest main loop (seconds): 0.004088; fastest: 0.000030
                                    Segments left: 0
                                    WiFi Vcc 3.10, reset reason Turned on by main processor
                                    WiFi flash size 4194304, free heap 39736
                                    • BlackTomundefined
                                      BlackTom
                                      David,, I just downgraded back to 1.18.1 and everything is fine, no more unexpected reset
                                      • minimundefined
                                        minim
                                        Sounds like the kind of crashes I had before but I upgraded to beta4 this morning and it's been printing now for 7-8hours without a crash yet. Seems like the bug I was experiencing is fixed now. I got a old-school cartesian setup tho so no corexy here.
                                        • cbusilloundefined
                                          cbusillo
                                          Hi guys. After updating the firmware, the machine becomes unresponsive. After turning it off and back on, it seems to revert to the last firmware. I had either Beta 2 or 3 on there. Bed leveling doesn't work. After resetting it still has the same Mac address, I believe that should have changed with beta 4. This is what displays after trying to update there firmware. I have done it with the web interface and the USB gcode method. Both produce the same results. THANKS!
                                          Firmware Electronics: Duet Ethernet 1.0
                                          Firmware Version: 1.19-b6 (2017-05-19)
                                          Web Interface Version: 1.16
                                          • minimundefined
                                            minim
                                            celebrated t o early 😄 Crashed now after trying to start a print. It became unresponsive and I had to reboot it by powercycle to get it back on. Just stopped mid-print like the other times. I'm rolling back to the version where the web interface is on own chip again to check if that removes these problems so I can see if it could be hardware related.
