Motors not working as they should
@mbunjes said in Motors not working as they should:
So I should run them at 1.2 A ? I can do that.
yes
Ok, upped the current to 1200 mA. The motors sound ok now but are still homing in the wrong direction. Changed the direction all is working well now.
Thank you very much -
Be careful with that. The motor direction of rotation and the homing direction are not the same thing. The direction of rotation will determine if +x moves to the left or right, but the homing direction is determined by the moves in the homing files. If you flip the motor direction of rotation when you should have changed the homing files you can get mirrored parts or broken homing.
Perhaps go through this commissioning guide.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
+x to the right, -x to the left, +y to the back, -y to the front
0,0 in the front left corner
Make sure the endstop positions are configured correctly in your M574 in config.g
And then make sure your homing moves have the correct + or - direction to move towards the endstop. -
Thanks, I'll have to study that. I'm new to Duet and new to corexy so it's a bit of a challenge.
I'm aware of the distinctions of homing and motor directions but they never seem to do what I want : x and y endstops at the right and back, 0,0 at the front left. And I have to discover where to make changes and what codes to use. But I'll get there.
The commissioning guide is for the Ender 3, isn't there something a bit more tailored to my situation ? -
The commissioning guide is pretty basic. checking motor directions and homing directions etc. It's pretty general to RRF.
If X endstop is at the right and Y at back then the endstops are at the high end of travel and it would be M574 X2 and M574 Y2. And the homing directions would be positive in direction.
For Corexy motor movement you'll also want to do these tests since XY movement is based on 2 motors moving together.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
Great thanks. My homework assignment for tomorrow.
All is not well yet. I have the motor directions correctly set up now, but moving has several issues. When I try to move the X axis, the Y axis moves and vice versa. When I try to home the X axis, the Z starts to move. When I try to home the Y axis , the X axis homes.
did you read the link phaedrux posted? what you need to do is described on that page.
I did exactly that and it helped, my axes move correctly now. + moves to +, the origin is at left front and the endstops at the right- back. But they don't respond correctly to the inputs from the DWC.
I did the
G91
G1 H2 X10 F3000
and it moves correctly, to the right and the back diagonally. -
G1 H2
that is a special command that just moves one motor
Yes, I wanted to test the X and Y separately.
Ok, progress. Homing now moves the correct axis but only the X endstop triggers. At the Y endstop it wants to keep moving.
have you read the documentation about endstops?
https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Testing_endstop_switches_using_M119 -
thats not what that command does. it just moves one motor
Yes.
M574 :
Endstop configuration:
X: high end switch connected to pin xstop
Y: high end switch connected to pin ystop
Z: high end Z probeI can stop the Y homing movement by triggering the endstop by hand.
Yes, I wanted to move just one motor
one motor move on corexy is a 45 degrees move
I know, that's what I wanted.
post your homing scripts
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 17 2020 16:33:25 GMT+0200 (Central European Summer Time)
G91 ; relative positioning
G1 H2 Z5 F12000 ; lift Z relative to current position
G1 H1 X365 Y385 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X365 ; home X axis
G1 H1 Y385 ; home Y axis
G1 X-5 Y-5 F12000 ; go back a few mm
G1 H1 X365 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y385 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X-19 Y15 F12000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F200 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X365 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F12000 ; go back a few mm
G1 H2 Z-5 F12000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y385 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F12000 ; go back a few mm
G1 H1 Y385 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X-19 Y15 F12000 ; go to first probe point
;G90 ; absolute positioning -
so what you are saying is that when during homing you press the y endstop, the homing stop, but when the carriage hits the y endstop it doesnt?
