    Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home
    4.8k
    • vistalertundefined
      vistalert @Veti
      @Veti Fair call ๐Ÿ™‚
      I'll make a new shorter length and try it on io5 then I also eliminate any issue on the port.
      Back soon!
      • Vetiundefined
        Veti @vistalert
        @vistalert
        no just plug it directly into the duet without an extension cable.
        this is just to test if it actually works
        vistalertundefined 2 Replies Last reply Reply Quote 0
          vistalert @Veti
          @Veti I can't as I don't have a fully intact original cable. I must've chopped the old end off to add the new connector for the D3, because I need the length due to the bed/frame size.
          Still puzzled though...I noted there are no continuity issues, and the out from io7 is registering with the BLT, proven by the probe deploying.
          Anyway will pursue this as suggested. Did you check out my config.g to see if I cocked anything up there? Is the pull-up "^" I keep reading about relevant on D3, with the P9 option?
          Pic here so you can see my dilema re the length of cable, it needs to go 500mm further back than where is now to to reach this shorter cable test.
            vistalert @Veti
            @Veti with a new shorter cable everything behaves exactly as before.
            Again, my same observation is if I reverse in/out the Z sensor shows 1000.
            With in/out the correct way around, the probe deploys and then touching it causes it to go into flashing red on/off, which I assume is error state.
            Are you able to confirm that the M558 / G31 commands are correct (notwithstanding you don't know my offsets are correct):
            M558 C"^io7.in" P9 H5 F100 T2000 R0.5 A4
            G31 P500 X0 Y36 Z2.7 ; set Z probe trigger value, offset and trigger height
            I don't know if the "^" is required or not. Do you have a BL Touch 3.1 you can try, or have tried with the D3?
            Thanks
            • Vetiundefined
              Veti @vistalert
              @vistalert
              the ^ is the pullup resistor and is the default
              the https://configtool.reprapfirmware.org/ configures this by default for the bltouch.
              have you checked the continuity of the wires from the bltouch?
              the connector looks questionable.
              vistalertundefined 1 Reply Last reply Reply Quote 0
                vistalert @Veti
                @Veti It's been tested from pin to pin. What you're seeing is just hot glue to keep everything stable so I can prove all of my components and then iterate forward to a more complete installation once I know how all the cables are going to be routed, and boards positioned etc.
                I'm 99.99999999% sure it's not a continuity issue. I've checked multiple times for shorts. I can't help agreeing with your gut feel there's a connectivity issue, but what I think we need to progress to is:
                How can we prove a signal is coming out of the BLT on its out signal. I can only quickly apply a multimeter, but I think it's a PWM signal coming back out right?
                  vistalert
                  @Veti I've check again from the connector going into io7, each pin, and traced continuity to the back of the socket on the BLTOUCH. All pins are good.
                  Brown/Black ground (tied togtether at BLT end)
                  Red -> +5v on D3
                  Yellow -> io7.out on D3
                  White -> io7.in on D3
                    vistalert
                    @Veti
                    Similar BLTOUCH issue with other boards/firmware
                    https://github.com/KevinOConnor/klipper/issues/2653#issuecomment-608998964
                    I see a lot of parallels with what this guy was experiencing with his BLTOUCH and not having the correctly configured pull ups. Are we 100% confident P9 has the pullup in place by default. It does appear critical for BLT 3.0 / 3.1
                    gshorten created this issue in KevinOConnor/klipper
                    closed BLTouch probe not working #2653
                    • Vetiundefined
                      Veti
                      yes
                      see
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                      M558 P9 C"^zprobe.in" H5 F100 T2000
                        vistalert
                        /\ Doesn't correspond to a D3 setup does it?
                        If P9 activates the pull up by default, why does that example show the use of ^ to activate the pull up.
                        That confuses me more.
                        • Vetiundefined
                          Veti
                          @vistalert said in Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home:
                          where does it say that p9 activates the pullup?
                            vistalert @Veti
                            @Veti not to split hairs...
                            I asked "Are we 100% confident P9 has the pullup in place by default."
                            You said yes ๐Ÿ™‚
                            So for a Duet3 (my specific context), would this be correct?
                            M558 P9 C"^io7.in" H5 F100 T2000
                            Thanks
                            • Vetiundefined
                              Veti
                              yes.
                              i said that is what is generated by default if you configure bltouch in the duet configurator.
                                vistalert
                                Thanks for confirming
                                No change in behaviour with the following in config.g
                                Home Z, bed continues to move when contact with probe has ocurred.
                                • Vetiundefined
                                  Veti
                                  can you post your homeall.g ?
                                    vistalert @Veti
                                    @Veti I haven't yet got a reliable homeall.g as I haven't commissioned the BLTOUCH.
                                    I have Home X and Home Y, which are sensorless (pending delivery of endstops)
                                    So what I'm trying for test purposes is this:
                                    1. Execute M401 - probe deploys - touch the end of the probe briefly enough to make the BLT light red. It must be released in < 650ms is my understanding, else it errors. At no time during repeated touches does the Z sensor in DWC show anything other than 0.
                                    2. I use a macro to drop the bed 10mm. I execute HOME Z - with my hand on the power button, because every time I test this, the bed is going to hit the nozzle.
                                    For what it's worth, this is the homeall.g I've built from copy / paste / learning about sensorless homing:
                                    My objectives here, home to front left using sensorless. Then move to centre of bed and probe there for Z home. Welcome your comments recommendations, as always.
                                    M400 					; wait til stuff stops
                                    M574 X1 Y1 S3 			; use stall guard for endstops
                                    M201 X2000 Y2000 		; reduce acceleration on X/Y to stop false triggers
                                    M915 P0:1 S3 R0 F0 H400	; both motors because corexy; Sensitivity 4, donโ€™t take action, donโ€™t filter, 400steps/sec
                                    G91 					; relative Positioning
                                    G1 H2 Z5 F1200			; lower the bed
                                    M913 X44 Y44  			; drop motor currents
                                    G1 H1 X-500 F5000 		; move until the motor stalls - COARSE HOME
                                    M913 X100 Y100  		; motor currents back to 100%
                                    G1 H2 X30 Y0 F1200		; move away from end
                                    M913 X32 Y32  			; drop motor currents
                                    G1 H1 Y-500 F4000 		; move until the motor stalls - COARSE HOME
                                    G1 H2 X0 Y10 F1200		; move away from end
                                    G90 					; back to absolute positioning
                                    M201 X3000 Y3000 		; accel back to original
                                    G90 					; absolute positioning
                                    G1 X250 Y250 F13000 	; Move x and Y axis over to bed center so probe is on top of bed
                                    M558 A1 F400 			; Set single probing at faster feed rate
                                    G30 					; Do a single probe to home our Z axis
                                    M558 A3 F100 			; Set tripple probing at slower feed rate
                                    G30 					; Probe again to get a more accurate position
                                    G28 X Y
                                    • Vetiundefined
                                      Veti @vistalert
                                      the bltouch pulse is so fast that you will not see it go to 1000.
                                      have you run the bltouch self test? its
                                      M280 P0 S120
                                      (edits it S120)
                                        vistalert
                                        I will try. But that runs on power up no?
                                        At power on, I see the pin bounce twice then the BLT tests with solid red LED.
                                        • Vetiundefined
                                          Veti @vistalert
                                          no the self test will retract and deploy the pin 10 times
                                          • Vetiundefined
                                            Veti
                                            what firmware version are you on (i hope the latest 3.1.1)
