firmware and filling of DUET 2
are you sure that you have installed firmware 3.1.1?
also
B1504
that is no thermistor that i know of. -
So here I am and ask for help as I'm new to this and don't understand anything
please read
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmwarei would also suggest your read this guide on how to go about it carefully
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37 -
na plate proshivka vrode 2.01
and you won't be able to configure the file ?
@Veti said in firmware and filling of DUET 2:
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37I would suggest you go through these guides to see how reprap firmware and the duet are used in practice. It may help you understand what's going on. It goes through connections, updating firmware, getting a config file set, and initial testing and calibration.
Tell me how to connect and make BL Touch work
sergei please consult the documentation
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
in most cases you will find documentation about the things you need to do
(btw this is also the first page that you get in google if you type in duet bltouch) -
Help. I can't understand why the printer's speed drops when printing in two colors
the extruder feeds the filament at a very high speed
We can't see what's happening, you'll have to show us the gcode being used. Everything in RRF is controlled by gcode, so if the printer is doing something, it's because it was commanded to with gcode. So show us the gcode and we can see what is happening.
[0_1603342686044_newtest2cveta.gcode](Uploading 100%)
@sergei
please wait after reaching 100% the file was not attached -
[0_1603343693346_newtest2cveta.gcode](Uploading 100%)
for some reason, an error pops up on the server
[0_1603346019893_бутылочка 2 цвета.zip](Uploading 100%)
https://cloud.mail.ru/public/4LcE/5uyj4ASrp
here is the link to the file
