    extruder fault problem and upgrade to 24v.
    496
    • Dave Parryundefined
      Dave Parry
      Cant find any info on heater bed power, but measuring resistance when cold gives 1.9 ohm which at 12v gives 6.3 amps which doesnt sound right. Neither of my multimeters go above 10a so their no use. Looking at similar square beds they seem to be about 200w. which would be about 15A
      Vetiundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @Dave Parry
        @Dave-Parry
        can you link the heater?
          Dave Parry
          https://www.amazon.co.uk/gp/product/B089ZYZGQW/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
          • Vetiundefined
            Veti @Dave Parry
            @Dave-Parry said in extruder fault problem and upgrade to 24v.:
            yeah that sound like a good guesstimate
              Dave Parry
              so say bed = 9 A,
              v6 40w = 1.6A
              nema 17 Stepper motors = 1.6A x 4, 6.4A
              Thats about 17A, so I think I need 20A. does that sound about right?
              I know the motors wont draw that much in realitity, but I think 24v 15 A is a bit low.
              • Vetiundefined
                Veti @Dave Parry
                @Dave-Parry
                see
                https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
                you need to calculate the nema differently
                  Dave Parry
                  So does that mean 2.8v x 1.68A = 4.5A per motor?
                    Dave Parry
                    My Bad, just read again and its 1,68A + 50%= 2.5A x 4 = 10A
                    So thats 20 A + other bits.
                    So probably 25A or 30A is going to be the required current.
                    Thats a lot, no wonder 12v 15A is having problems.
                      Definitely consider a meanwell supply from a reputable supplier like digikey or mouser.
                        Dave Parry
                        Next problem is a power connector. 25 amps is a lot for a connector to handle.
                        My present one is a 8 way one, 3 for +, 3 for -, and 2 I think are for power switch.
                        Not sure what type they are but I think they are molex ones. What type do other machines use?
                          Phaedrux Moderator @Dave Parry
                          I'm not sure what you're referring to? Photo?
