CNC Touch Plates recommendation needed
CNC
    Jamesmiller56
    Hey, I am Jamesmiller. I need little help from you guys. I think you guys will surly able to help me.
    I am thinking to purchase a CNC Touch Plates but i lack complete knowledge on which one is best. This is first time i am purchasing it. I also google for help i got reference an article mentioned below after reading i got some information.
    https://theedgecutter.com/best-cnc-touch-plates/
    I think SainSmart CNC Touch Plate, Huanyu Plate will be good. My budget is low so looking for an affordable option that's struggling a bit in finding good one.
    So need your reviews and suggestion on good CNC Touch Plates at cheaper pricing
    Thanks in advance
      jay_s_uk
      I have the cheapest I could get on Amazon.
      Works well
        Jamesmiller56
        Thanks for suggestion
          Arcnsparks
          Unless you just like the ease of use, or convenience of buying one online, there's really no need. I use a small copper clad proto board that I never etched. I cut it to a handy shape and soldered a wire to it. I have a banana plug that I use to plug it in to a panel mounted jack, instead of the alligator clip.
          Basically, you can use anything that's conductive and that has an easily measurable Z height. Heck, I've used tin foil wrapped around the part when I wanted to find exact Z of a previously failed part in order to continue where I left off, lol.
            josehenry1800
            Thanks for your valuable answer.
            Woodworker and Blogger
              Sindarius
              If you want to go super meta you could do what this guy did. 3d printed a plate and covered it in aluminum tape.
              https://www.reddit.com/r/hobbycnc/comments/km1w2x/made_a_poor_mans_xyz_probe_using_3d_printed_piece/
                warrut981
                I'm also looking for the sources to new CNC reviews and all, Currently I'm using tools like thickness planer and table saw. but I also planning for to add CNC to new production.
