Dual Hotend setup
Good Afternoon, looking for any help, anyone can provide. I have a DIY 3d printer that I have built myself from the ground up. It has all liner rails, dual screw on the z axis and all of this is ran by a DUET maestro. I started with a single hot-end and extruder with a BL Touch and everything printed great am printing on a glass bed also. Every print was dead on and came out perfect. I decided to move to a dual extruder and hot-end. I went with a E3D Chimera, I did swap out the 0.4 nozzles for some 0.6 stainless steel ones (I am not sure if this is part of my problem or not. I have the bed level, my z offset is set. I am printing standard PLA at 210 and have my bed-headed to 60. I am just trying to print a simple 2 color cone, to test everything out. I have both nozzles set to the same z. When I start printing, my first layer is good and sticks well, my first color seems to print ok, but I seem to have a clogged nozzle every time my second color gets ready to go. I keep both hot ends at 210 even in standby, so they are ready to print. I also have a part cooling going after the second layer goes down.
Are stainless steel nozzles prone to clogging easily? What else can I look at to get this printing correctly? I never thought a dual hot-end would be this hard to set up, especially when the printer was printing great with just the one nozzle.
Any help or pointers would be greatly appreciated.
@yagodajm said in Dual Hotend setup:
that is almost certainly your problem. stainless steel is terrible for heat transfer. you will have to print a way high temperatures with it.
@Veti Thank you, I thought that was it, but just wanted to make sure. I guess I will get some different ones.
Thanks,
Justin -
i am waiting for my copper plated ones to arrive.
@Veti Cool, let me know how they work out. I put .6 brass on and I am still having issues, now I can't even get a first layer to stick. Both of my nozzles touch the bed when I set z 0 and then I run my mesh leveling. I am still trying to figure this dual nozzle thing out. I order a 2 in 1 out mixing one to see if I can get better results.
when you change nozzles you need to measure you z probe offset again.
