    Dual Z Motors single Z Probe as end stop for each motor
    Firmware installation
    • Bluemaluundefined
      Bluemalu
      I've got my dual z motors working.
      ; bed.g
      ; Setup for bed levelling using multiple independent Z motors
      G28 ; Home
      G30 P0 X0   Y100 Z-99999 ; Z probe Left side lead screw
      G30 P1 X255 Y100 Z-99999 ; Z probe Right side lead screw
      and edited config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 16:22:11 GMT+0000 (Greenwich Mean Time)
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"Duet 3"                                         ; set printer name
      M569 P0.0 S1                                           ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                           ; physical drive 0.1 goes backwards
      M569 P0.2 S0                                           ; physical drive 0.2 goes backwards
      M569 P0.3 S0                                           ; physical drive 0.3 goes backwards
      M569 P0.4 S1                                           ; physical drive 0.4 goes forwards
      M569 P0.5 S0                                           ; physical drive 0.5 goes backwards
      M584 X0.0 Y0.1 Z0.2:03 E0.4:0.5                        ; set drive mapping X,Y,Z0,Z1,E0,E1
      M350 X16 Y16 Z16:16 E16:16 I1                          ; configure microstepping with interpolation
      M92 X160.00 Y360.00 Z800.00:800.00 E304.00:304.00      ; set steps per mm
      M566 X900.00 Y900.00 Z60.00:60.00 E120.00:120.00       ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z600.00:600.00 E4500.00:4500.00 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z20.00:20.00 E1000.00:100.00      ; set accelerations (mm/s^2)
      M906 X1360 Y1600 Z1344:1344 E1360:1360 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                ; Set idle timeout
      M208 X0 Y0 Z0 S1                                       ; set axis minima
      M208 X260 Y240 Z280 S0                                 ; set axis maxima
      M574 X1 S1 P"io1.in"                                   ; configure active-high endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in"                                   ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
      M558 P1 C"io3.in" H5 F120 T6000                        ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z1.888                                  ; set Z probe trigger value, offset and trigger height
      M557 X0:240 Y0:160 S40                                 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4267           ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                     ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs0" Y"rtd-max31865"                     ; configure sensor 1 as thermocouple via CS pin spi.cs0
      M950 H1 C"out1" T1                                     ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"spi.cs1" Y"rtd-max31865"                     ; configure sensor 2 as thermocouple via CS pin spi.cs1
      M950 H2 C"out2" T2                                     ; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out7" Q500                                   ; create fan 0 on pin out7 and set its frequency
      M106 P0 S1 H-1                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                                   ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1                                         ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out4" Q500                                   ; create fan 2 on pin out4 and set its frequency
      M106 P2 S1 H1 T45                                      ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"out5" Q500                                   ; create fan 3 on pin out5 and set its frequency
      M106 P3 S1 H2 T45                                      ; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"out9" Q65535                                 ; create fan 4 on pin out9 and set its frequency
      M106 P4 S1 H1:2 T45                                    ; set fan 4 value. Thermostatic control is turned on
      M563 P0 S"Left Extruder" D0 H1 F0                      ; define tool 0
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"Right Extruder" D1 H2 F1                     ; define tool 1
      G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
      G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
      ; Custom settings
      M671 X-35:335 Y100:100                                 ; Define positions of Z Axis lead screws
      M307 H0 A233.6 C1178.2 D0.5 V24.1 B0                   ; Heated Bed Calibration 26/10/20
      M307 H1 A327.8 C161.2 D2.8 V24.2 B0                    ; Left Extruder Heater Calibration 17/10/20
      M307 H2 A325.8 C160.8 D3.4 V24.2 B0                    ; Right Extruder Heater Calibration 17/10/20
      M106 P0 S0                                             ; Turn Fan 0 OFF
      M106 P1 S0                                             ; Turn Fan 1 OFF
      M575 P1 S1 B57600                                      ; enable support for PanelDue
      T0                                                     ; select first tool
      When I issue a G32 the code in bed.g is executed and detects the two points and calculates the appropriate offsets.
      I would like it level the bed instead ie use the Z probe as an endstop twice and move it the homez.g, then I can use the various meshs for the bed. Is this possible?
      • Vetiundefined
        Veti @Bluemalu
        @Bluemalu said in Dual Z Motors single Z Probe as end stop for each motor:
        i dont unserstand what you mean, but your bed.g is incorrect
        its missing the S2
        see
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        Bluemaluundefined 1 Reply Last reply Reply Quote 0
        • Bluemaluundefined
          Bluemalu @Veti
          @Veti Thanks for that spot, I'd missed the S2 to calculate the new plane.
          Ignore my question, I've just written it down in a different way and have seen what I am asking is impossible or at least potentially dangerous given the bed is one piece and the steppers don't have a feedback position (think I've played with servo motors for too long).
          I suppose my question should be can you carry out the dual probe and then carry out a mesh calibration or is it pointless?
          • Vetiundefined
            Veti @Bluemalu
            it depends on the quality of your bed. if your bed is very flat then its pointless.
            if your bed is not flat but does not deform because has a high with, then you can just reload the mesh without probing again.
            otherwise its a good idea to do a G29 after the G32.
            • Bluemaluundefined
              Bluemalu
              Perfect, bed is a piece of 6mm tooling aluminium with little flex so no point in over egging the pudding.
              Time to start printing as that was my last query from my upgrade.
