    Ok to use UI slider for LED lighting control?
    • Nonproductiveundefined
      Nonproductive
      I didn't see anything specific to this question - so thought I would add it in here:
      It occurred to me that the LED strips on my machine are powered simply by using one of the Fan connectors.
      Right now I turn them on with "M106 P2 S255" and off with "M106 P2 S0"
      The Duet Board allows you to display the fan sliders in the UI.
      So..my question:
      Are there any dangers to the electronics or LED strips in using the UI Fan 3 slider as a dimmer for the LEDs? Or is it best to use them in Off/On modes only?
      Thanks in advance -
        It's OK to use PWM on ordinary LED strips, so you can use the sliders.
          Nonproductive
          Thank you, sir!
