calibration IR probe RRF3
@Rudy2A come now, don't despair. We will get you there eventually, but only if you don't give up.
Can you post your current config.g please?
Double Z/U axis is not needed in RRF3 if you intend to do leveling with two endstops. You only need a U axis if you want manual control of both Z motors.
In your config above you have these pins define, but those are pin names for the Duet 3. The rest of your pin names for for Duet 2. I think this may be the cause of the invalid use of P parameter.
Can you restate the current problem?
First of all, I want to say that I have absolutely nothing against this forum and the people who make it live ... I blame myself and especially not the community for doing its best.
You should also know that I do not speak English and it is very difficult to make yourself understood or to understand you in your answers.
My issue is the following :
I am using a Duet 2 under RRF3.1.1. I absolutely cannot get my Double Z (Z and U) to work independently to level my bed. One of the Z motors is connected to Drive 2 and the other to Drive 4.
When I do a G32, I see the axes (M671) which restore my possible inclination, it works without any problem. On the other hand, for the future with the M557 which runs my two motors, but symmetrically so they do not correct anything since they move equally. I think my whole configuration is corrupted now by dint of modification.
Config.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 11:25:15 GMT+0100 (CET); General preferences
M550 P"My Printer+" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M569 P4 S0M584 X0 Y1 Z2:4 U4 E3 P3 ; set drive mapping
M671 X-58: 317 Y132: 132 S10; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de repère XM350 X16 Y16 Z16 U16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600.00 U1600.00 E830.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 U60.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
M203 X11639 Y11639 Z200 U200 E600 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z40.00 U40.00 E300.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 U950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z-0.5 U0-0.5 S1 ; set axis minima
M208 X270 Y270 Z245 U245 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 P"io2.in" ; Axe Z avec deux moteurs, butées min.; Z-Probe
M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X-19 Y6 Z2.58 ; set Z probe trigger value, offset and trigger height
M557 X11:250 Y11:252 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
; Custom settings are not definedBed.g
; bed.gG28 ; Home all Axes
M561 ; Efface la correction de plan
M290 R0 S0 ; Efface Baby-stepping; Bed levelling (G32)
G30 P0 X0.0 Y132 Z-99999; sonde près d'une vis sans fin, à mi-chemin le long de l'axe Y
G30 P1 X260 Y132 Z-99999 S2; sonde près d'une vis et calibrez 2 moteurs; Espace de sondage
M557 X11:250 Y11:252 P2 ; Définir la grille maillée; Compensation de maillage (G29)
G29 S0homeall.g
G91 ; relative positioning
G1 H2 Z2 F6000 ;
G1 H1 X-275 Y-275 F1000 ; se déplacer rapidement vers la butée X ou Y et s'arrêter là (premier passage)
G1 H1 X-275 ; home X axis
G1 H1 Y-275 ; home Y axis
G1 X4 Y4 F600 ; retour légerement en AR (calage)mm
G1 H1 X-10 ; déplacement lent vers le fin de course de l'axe X
G1 H1 Y-10 ; déplacement lent vers le fin de course de l'axe Y
G90 ; absolute positioning
G1 X129 Y132 F6000 ; Sonde le Z0
G30homez.g
G91 ; Relative mode
G1 Z250 U250 F2000 S1 ; Move up to 250mm in the +Z direction. S1 to stop if endstop is triggered
G1 Z-2 U-2 F600 S2 ; Move 2mm in the -Z direction - (I'm not sure what S2 is for?)
G1 Z3 U3 F100 S1 ; Move slowly 3mm in the +Z direction, stopping at the homing switch
M584 Z2:4 ; Join U to Z again (pay attention to drive numbers used)
G1 Z-5 F3000 ; Move back again 5mm in the -Z direction
G90 ; Back to absolute mode -
@Rudy2A said in calibration IR probe RRF3:
You do not need this. io2.in does not exist on your duet 2. and you don't need to define a z axis endstop if you're using the probe.
Double Z (Z and U)
You do not need a U axis at all to do leveling using G32/bed.g as you have now.
homez.g
G91 ; Relative mode
G90 ; Back to absolute modeThis is unnecessary if you are using bed.g to do the leveling.
Remove the U4 and all references to the U axis in M92, M350, M566, M203, M201, M906, M208. Remove the P3 as well. You don't need it.
Remove the space after :Once you have done all of that, G28 should home all axis, and then G32 should perform tilt correction.
Apparently, it seems to be out of order (to watch out for) ...
I still have a slight problem calibrating my probe (mini IR).
When it raises its value.=>>
"Nozzle in the center of the bed (usual temperature)
Put the nozzle in contact with the tray (or the sheet of paper)
G92 Z0 (Z = 0)
Lift the 5mm nozzle (G92 Z5)
G30 S-1
Read the z value
G31 Z xxx"I get a height of 2.74 and if I indicate this value G31 Z2.72 my first layer is too crushed ... On the other hand if I go down to 2.62 in manual G31 Z2.62, it is good. Is such a Delta normal?
I am in doubt about my order for the probe, does this seem correct to you?
G31 P500 X-19 Y6 Z2.62Thank you one more for your help!
yes, the first step is just to get a close value.
fine adjustment should always be made afterwards. -
Thank's @Veti
A small clarification on my values.
If I adjust my leveling on 2 points, my first coat is impeccable. (probe at the four corners of the bed) M557 X11: 250 Y11: 252 P2
If I adjust my leveling on 3 points, my first layer is much too high (probe at the four corners and in the center) M557 X11: 250 Y11: 252 P3
Please note that this is the same part that I am printing and no changes have been made.
It depends if you bed is perfectly flat.
If true, g32 is enought
if false, g32 + g29 is needed. -
In both cases I do a G 32 + G29, all in a bed.g file
; bed.g
G28 ; Home all Axes
G29 S0 -
i dont think that the bed.g should contain a G29. or a M557 .
if you cant G32 + G29 you should create a macro
You may want to add a single G30 at the center of the bed after the G30 P0 G30 P1 lines so that any change in height caused by the tilt correction is captured before the heightmap is created.
@Phaedrux said in calibration IR probe RRF3:
I did not understand everything ... Like that?
; lit.g
G28 ; Home all Axes
G30
G30
; Espace de sondage
G29 S0 -
G30
G30No, like this:
G1 X150 Y150 ; move to center of bed
G30 ; probe bedChange the x150 y150 to be whatever values you need to move the probe to the center of the bed.
@Phaedrux Thank you, I'm testing ...
