    Duet Web control is not available at time of printing
    Duet Web Control
    825
    • DronBroksundefined
      DronBroks @Veti
      @Veti
      I sent the first command while printing. Printing was interrupted, now only after work I can start printing again. In essence, the main question - after transferring the Ethernet cable outside the printer case, the Web server does not hang up yet.
        With the high microstepping it's possible that you're saturating the CPU and it's not able to service the web interface requests quickly enough during a print.
        Please test with x16 microsteps and interpolation enabled.
        DronBroksundefined 2 Replies Last reply Reply Quote 1
          DronBroks @Phaedrux
          @Phaedrux
          Good. After the work is checked.
            DronBroks @Phaedrux
            @Phaedrux
            After the transfer of the Ethernet cable from the printer body, hovering stopped interface (tested on a daily print interface can be accessed at any time)
            jovo0911undefined 1 Reply Last reply Reply Quote 0
            • jovo0911undefined
              jovo0911 @DronBroks
              @DronBroks said in Duet Web control is not available at time of printing:
              @Phaedrux
              Any new infos here? I have also a problem with network connection. Sometimes I lost connection (mostly after upload a file - bigger then 10 mb)
                Phaedrux Moderator @jovo0911
                @jovo0911 Might want to start a new thread with your specific details.
                  DronBroks
                  Good afternoon!
                  Problems continued, but less frequently. Most often, the problem appears when you create a folder on the memory card, or transfer to the card volumetric files. Sometimes the interface freezes during long-term work. And it is such that when downloading files pauses printing for a split second.
                    @DronBroks Can you confirm that you have switched to x16 microstepping?
                    Do you have a new SD card to test with?
                    DronBroksundefined 2 Replies Last reply Reply Quote 0
                      DronBroks @Phaedrux
                      @Phaedrux Yes, I switched to 1x16 microsteps. Perhaps the reason is actually in the memory card. I’m not very fast. Today I will buy a new one and check with a new card
                        DronBroks @Phaedrux
                        @Phaedrux
                        ; Configuration file for Duet Maestro (firmware version 3)
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 23 2020 13:34:11 GMT+0300 (Москва, стандартное время)
                        M80
                        M550 P"Dron Printer" ; set printer name
                        M669 K1 ; select CoreXY mode
                        M551 P"" ; set password
                        M552 P192.ххх.ххх.ххх S1 ; enable network and acquire
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0 S1 D3 ; physical drive 0 goes forwards stealthChop2
                        M569 P1 S1 D3 ; physical drive 1 goes forwards stealthChop2
                        M569 P2 S1 D3 ; physical drive 2 goes forwards stealthChop2
                        M569 P3 S0 D3 ; physical drive 3 goes forwards stealthChop2
                        M350 X16 Y16 Z16 E32 I1 ; configure microstepping interpolation
                        M92 X80.00 Y80.00 Z804.875 E1001 ; set steps per mm
                        ; Jerk
                        M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) Jerk
                        ; Maximum Speeds
                        ; Accelerations
                        M201 X1000.00 Y1000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                        M204 P1000 T5000 ; Maximum printing acceleration 1000.0, maximum travel acceleration 5000.0
                        M906 X900 Y900 Z900 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X300 Y300 Z240 S0 ; set axis maxima
                        M574 X1 S1 P"!xstop" ; configure active-low endstop for low(min) end on X via pin xstop
                        M574 Y2 S1 P"!ystop" ; configure active-low endstop for high(max) end on Y via pin ystop
                        M574 Z1 S2 ; configure Z-probe endstop for low(min) end on Z
                        M591 D0 P5 C"e0_stop" R50:140 E4.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 7mm comparison length, enabled
                        M558 P9 C"zprobe.in" H5 F120 T3000 ; BLTouch set Z probe type to unmodulated and the dive height + speeds
                        M950 S0 C"zprobe.mod" ; BLTouch servo/gpio 0 is Z probe MOD pin
                        M280 P0 S10 ; BLTouch send control signal to BLTouch through servo/gpio 0
                        M280 P0 S90 ; Send PWM channel 0 the S90 (angle) command
                        G31 P25 X-2.7 Y-50.6 Z1.54 ; BLTouch set Z probe trigger value, offset and trigger height
                        M557 X10:290 Y10:290 S20 ; probe from X=10 to 290, Y=10 to 250mm with a mesh spacing of 20mm
                        M308 S0 P"bedtemp" Y"thermistor" R2200 T100000 B3950 A"Stol-Temp" ; configure sensor 0 as thermistor on pin bedtemp
                        M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                        M143 H0 S130 ; set temperature limit for heater 0 to 130C
                        M308 S1 P"e0temp" Y"thermistor" R2200 T100000 B3950 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
                        ; M308 S1 P"e0temp" Y"pt1000" R2200 A"Nozl_0-Temp" ; configure sensor 1 as thermistor on pin e0temp
                        M308 S2 P"ctemp" Y"thermistor" R2200 T100000 B3950 A"Drivers-Temp" ; configure sensor 2 as thermistor on pin сtemp
                        M308 S3 Y"mcu-temp" A"MCU-Temp" ;
                        M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 S1 H2 T40 ; set fan 2 value. Thermostatic control is turned on
                        M501
                        M200 D1.75 ; set all extruder filament diameters to 1.75mm
                          Phaedrux Moderator @DronBroks
                          Yes please test with a new SD card. When you do so, replace the files in the /www folder with a fresh set from the DWC 3.1.1 zip file.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
                          Also try with a different ethernet cable, just in case.
                          DronBroksundefined 1 Reply Last reply Reply Quote 0
                            DronBroks @Phaedrux
                            @Phaedrux said in Duet Web control is not available at time of printing:
                            I replaced the SD card with a new (class 10), the DWC has updated the files, replace the cable. As a result, the DWC fell off after 8 hours printing. On the old card it occurred 5-6 hours after printing
                              Can you share one of your volumetric gcode files?
                              Do you have a large number of nested folders?
                              Can you try a different ethernet port on your switch/router?
                                DronBroks @Phaedrux
                                And where to put this file?
                                  DronBroks @Phaedrux
                                  There are many subfolders (each project has its own folder). But this problem does not depend on the depth of nesting. The interface also freezes if you print a file from the root of the card and from a subfolder.
                                    If it's too large to upload directly you can try zipping the gcode file and then changing the file extension to .txt and uploading that. Otherwise put it on dropbox or google drive and share a link.
                                    I was just speculating that a large number of folders could be causing DWC to spend a lot of time searching recursively through folders causing issues.
                                    One way to test would be to place your SD card in aPC, cut and paste the contents of the gcodes folder to your PC as a backup, and then see if the DWC still has problems responding.
