    RRF and Heaters – Duet 2 WIFI 3.1.1
    1.7k
    • Vetiundefined
      Veti @MJCT
      @MJCT
      thats you config-overwrite not your config
      MJCTundefined 1 Reply Last reply Reply Quote 0
      • MJCTundefined
        MJCT @Veti
        @Veti Sorry
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M143 H0 S110 ; set temperature limit for heater 0 to 110C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
        M140 H1 ; map heated bed to heater 0
        M143 H1 S290 ; set temperature limit for heater 0 to 110C
        M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
        T0 ; select first tool
        M501
        • Vetiundefined
          Veti @MJCT
          @MJCT
          yes
          MJCTundefined 1 Reply Last reply Reply Quote 1
          • MJCTundefined
            MJCT @Veti
            @Veti And another problem arises.
            On my touch screen I’m only getting readings for temperature under the “bed Icon”, nothing appears bellow the “nozzle icon”.
            Web interface shows readings both for extruder 1 and bed. When I request the temperature to rise in one of them, they both show the same target temperature but only the extruder 1 curve moves up
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Nov 12 2020 15:24:07 GMT+0000 (Hora padrão da Europa Ocidental)
            M550 P"AA 300x300x600" ; set printer name
            M669 K1 ; select CoreXY mode
            M551 P"AA" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M92 X80.00 Y80.00 Z400.00 E98.50 ; set steps per mm
            M566 X950.00 Y950.00 Z30.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z1000.00 E3300.00 ; set maximum speeds (mm/min)
            M201 X3100.00 Y3100.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
            M906 X1850 Y1850 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X10 Y10 Z0 S1 ; set axis minima
            M208 X300 Y300 Z570 S0 ; set axis maxima
            M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
            M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P25 X24 Y0 Z2.425 ; set Z probe trigger value, offset and trigger height (quanto mais elevado Z, mais proximo da mesa)
            M557 X50:250 Y50:250 S25 ; define mesh grid
            M501
            • Vetiundefined
              Veti
              what firmware are you running on the paneldue?
              • MJCTundefined
                MJCT @Veti
                @Veti 1.24
                • MJCTundefined
                  MJCT
                  Under "Heat" is it every thing normal?
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                  Board ID: 08DJM-9178L-L4MSJ-6J9F0-3S46Q-KT3YP
                  Used output buffers: 3 of 24 (13 max)
                  Static ram: 27980
                  Dynamic ram: 93884 of which 60 recycled
                  Exception stack ram used: 304
                  Never used ram: 8844
                  Tasks: NETWORK(ready,308) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:21:42 ago, cause: power up
                  Last software reset at 2020-11-13 12:09, reason: User, spinning module GCodes, available RAM 8836 bytes (slot 0)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 43.0, current 49.1, max 49.4
                  Supply voltage: min 23.7, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                  Date/time: 2020-11-13 13:30:55
                  Cache data hit count 2136812117
                  Slowest loop: 13.47ms; fastest: 0.14ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 4.1ms, write time 6.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Bed heaters = 1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                  Heater 1 is on, I-accum = 0.2
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 26.07ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address ec:fa:bc:01:d4:c6
                    WiFi Vcc 3.38, reset reason Unknown
                    WiFi flash size 4194304, free heap 24528
                    WiFi IP address 192.168.10.62
                    WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                  • Vetiundefined
                    Veti
                    i dont see anything unusual. maybe someone else can have a look?
                    • MJCTundefined
                      MJCT @Veti
                      @Veti Funny
                      Just deleted the 2 lines that I added manually to the config (M140 and M143) and everything went back to normal
                      How can this be?
                      • MJCTundefined
                        MJCT
                        Adding M143 H1 S290 and everything stays normal
                        Adding M140 H1and everything gets broken again
                        This M140 H1 command for the nozle makes all the difference
                        • Vetiundefined
                          Veti @MJCT
                          @MJCT
                          that makes sense.
                          this means that the heater is designated to be a bed heater.
                          you dont want to do that for H1, as it is not a bed heater.
                          • MJCTundefined
                            MJCT @Veti
                            @Veti that said, don't I need to map it anyway with some other M140?
                            I just leave it like that?
                            • Vetiundefined
                              Veti @MJCT
                              @MJCT
                              yes
                              • MJCTundefined
                                MJCT @Veti
                                @Veti Ok, thank you very much for all this hours that you spent helping me
