    3.2b3: XY stalls when bed compensation activated
    Beta Firmware
    492
    • SAtechundefined
      SAtech
      Just to add another data point, I have also experienced this same behavior. However, I am running a duet 2, also on corexy.
      Edit: I have observed this since RRF 3.1.1.
      • TypQxQundefined
        TypQxQ
        I did run M122 while printing with bed compensation enabled and the "comp offset" is allways 0.000. Is that normal?
          It's common to experience this when a low Z jerk is set, to the point there is an entry for it in the mesh compensation documentation.
          https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Troubleshooting
          Try increasing your Z jerk. M566 Z100
          TypQxQundefined 1 Reply Last reply Reply Quote 0
          • TypQxQundefined
            TypQxQ @Phaedrux
            @Phaedrux tried even M566 Z500 and was no diffrence.
            I reasoned that if it would be from xy moving to fast for z, then why would it be worse at a slower xy speed?
            • TypQxQundefined
              TypQxQ
              Feels like I've tried everything now.
              XY loses steps regardless what I do to the acc, jerk and speed.
              Even raising the currents by 30%.
              M203 X18000 Y18000	; Max speed 300mm/s
              M203 Z24
              M201 Z1000
              M566 Z1000
              M201 X500 Y500
              M566 X300 Y300
              G1 F12000
              I've tried this too with my finger on emergency reset..:
              M203 Z100
              M201 Z1000
              M566 Z1000
                Two things I would check.
                First see if there is any other Z jerk M566 command in another macro that is getting called. homeall or the like.
                You can also send M566 during the test to get a read back of the current value, just to double check it's not actually getting changed.
                The other thing would be to copy your config and macro files over to a new SD card and get it setup for standalone operation without the SBC. If the problem goes away then we've narrowed it down to DSF.
                https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
                • chrishammundefined
                  chrishamm administrators @Phaedrux
                  @Phaedrux There will be a fix for jerky movements in SBC mode in the next 3.2-b3+1 release. It won't take much longer before we release it.
                  @TypQxQ please check out this post.
                  Duet software engineer
                  TypQxQundefined 3 Replies Last reply Reply Quote 2
                  • TypQxQundefined
                    TypQxQ @chrishamm
                    @chrishamm Upgraded to ” RepRapFirmware for Duet 3 MB6HC version 3.2-beta3+3-ch running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)” and looks like it fixed both the missed stepps and the stuttering.
                    Ran the macro above and runs well even at 500mm/s.
                    Doing a multitool testprint now.
                    • TypQxQundefined
                      TypQxQ @chrishamm
                      Thanky @chrishamm!
                      It works great now!!!
                      • TypQxQundefined
                        TypQxQ @chrishamm
                        @chrishamm Do you know if the new changes from ”3.2-beta3+3-ch” are included in the new ”3.2beta3.2” beta?
                        Didn’t see it in the changelog.
                          chrishamm administrators @TypQxQ
                          @TypQxQ Yes, those changes have been merged into the new beta as well.
