    M98 not working "macro file not found"
    1.6k
    • ThePigSlayerundefined
      ThePigSlayer
      So I have run out of ideas, I cant get M98 to work. Macro file name is simply "test", so I thought M98 Ptest.g would work, but nope, haven't gotten it or the many variations I have tried to work, including turning off "covert all gcodes to capitals". I also tried to specify the internal SD card with P0 but that didn't work either.
      I also took out my microSD card, and reformatted it, made sure I had the correct folder structure (https://duet3d.com/wiki/SD_card_folder_structure)…. its still not working.
      Does anyone have any ideas? I had it working fine previously, so I have no idea how to fix this.
      Thanks in advance for any help!
      • Jackalundefined
        Jackal
        Try [c]M98 P/macros/test[/c]
          ThePigSlayer
          that worked! thank you so much
          do you know the reason why?
          • Jackalundefined
            Jackal
            I haven't used M98 before
            I just looked it up the wiki
            Not sure why it worked before for you but not now
            The wiki says the default path is /sys and some firmware will look into /macros
            So probably RRF skips /macros
