    Timelapses, are they possible?
    Third-party software
    2.6k
      A Former User @Veti
      @Veti said in Timelapses, are they possible?:
      see
      https://github.com/kriechi/DuetRRF-timelapse
      It's exactly what I've read but I can't find a Wiki to understand how to use it...I'm not a Raspberry expert so for me the issue are:
      • Raspberry Pi / Single-Board Computer on the same network as your Duet
        with Python 3 and the requests package
      • Webcam that returns snapshot pictures (still image) via an URL
        mjpg-streamer or similiar: http://127.0.0.1:8080/?action=snapshot
      I think that I had to "throw away" motion eye, right? Or is it possible to use it feature to have an URL fort he still images?
      In case not should I install only Python 3 and mjpg-streamer to my Raspy?
      Thanks
      Andrea
      p.s.
      as you can see I'm not a Raspberry/Linux expert....sorry
      • Vetiundefined
        Veti
        @the_dragonlord said in Timelapses, are they possible?:
        if it can produce single images then no, otherwise yes.
          A Former User @Veti
          It produces single images
          But I can't undesrstand how the command M118 P4 S"LAYER CHANGE" ; take a picture could trigger the shooting of a pic....where do I have to put the URL given? In the web control? I am missing something...
          • Vetiundefined
            Veti
            the python script enables a telnet connection to the duet and listens for the "LAYER CHANGE" info
            the webcam url is an option for the python script
            • resamundefined
              resam
              I'm the author of https://github.com/kriechi/DuetRRF-timelapse - Ask me Anything 😃
              Generating timelapse videos is quiet an opinionated topic in 3D-printing - everybody has a slightly different setup and preferred way of doing it. This is how I currently run my printer setup:
              There are two things needed to make print-synced timelapses:
              • your slicer needs to insert the M118 commands on every layer change
              • your raspberry pi needs to run the timelapse.py script
              You need to enable Telnet support in your Duet board with M586 P2 S1.
              You can start the timelapse script on your RaspberryPi like this:
              ./timelapse.py some-folder-for-all-images/ 192.168.1.42 http://127.0.0.1:8080/?action=snapshot
              (with the IP address of the Duet printer, and the URL is in my case mjpg-streamer returning a single jpg image)
              A Former User? 2 Replies Last reply Reply Quote 1
                A Former User @resam
                @resam said in Timelapses, are they possible?:
                ok, now the fog starts to raise a little....so, in order:
                1. I can keep motion eye on my Raspy and install Python 3 and then copy timelapse.py on the Raspy SD
                2. I have to insert the M118 in the layer change as you wrote on github:
                  M400 ; wait for all movement to complete
                  G4 P500 ; wait a bit
                  does this work on IdeaMaker too (I think so)
                3. Do I have to execute manually each time the launch of the script and the timelapse rendering? Isn't it possible to execute them automatically in some way?
                4. Least and last I didn't understand where the final timelapse MP4 will be stored...
                Thanks for your help
                • resamundefined
                  resam
                  1. I'm not familiar with motioneye - if you find a URL that you can call and it returns a single still frame as jpg or png, then yes.
                  2. I'm not familiar with IdeaMaker - most slicers have some "on layer change" script section were you can enter a few g-code commands
                  3. with a bit of Linux knowledge it should be easy to do - with varying levels of complexity. I would recommend searching the web for "crontab" or "systemd" in this context
                  4. All the still frames and the final rendered movie will be in the folder path you passed to the timelapse script as first argument
                  A Former User? 2 Replies Last reply Reply Quote 0
                    ok, thanks! I'll do some searching and testing!
                      Hi, I've installed everything but it doesn't work (of course I've missed something).
                      If can help when the I connect with putty I get this error message:
                      this is what I've inserted in etc/profile:
                      sudo python /home/pi/timelapse.py timelapses/ 192.168.1.7 http://192.1.168.13:8080/?action=snapshot
                      • resamundefined
                        resam
                        try with sudo python3 ....
                        python is the old version - python3 is the new one (which you need).
                          This post is deleted!
                          • resamundefined
                            resam
                            go and run: python -V and then python3 -V
                            You will probably see that the first one returns 2.7.something and the other one 3.something.else.
                            We need 3.something for the timelapse script to work.
                            You can also avoid this monkey dance by simply calling the timelapse script itself:
                            sudo /home/pi/timelapse.py timelapses/ 192.168.1.7 http://192.1.168.13:8080/?action=snapshot
                              uh ok....I'm not a Linux expert....I've change from python to python3 and now no error appear logging into....I've started a trial print to see if all works...I'll let you know in few minutes!
                                it's printing but I don't see images going into the folder as long as layers changes
                                • resamundefined
                                  resam
                                  just start the script in the interactive console (putty) directly. It should print a few log lines so we can see what is happening.
                                    • resamundefined
                                      resam
                                      Did you enable Telnet in your printer config?
                                        yes
                                        • resamundefined
                                          resam
                                          ok - that looks right. However it is failing to send commands to the printer...
                                          Does the error message repeat after 15-20 seconds?
                                            yes it does
