bltouch config
@Phaedrux
i becomes more and more confusing now
where do i find this in the online config tool ? -
see my post from above
@Kolbi
i does not say anything about the online config tool -
thanks
is this all that i have to do or do i have to make some changes in the config file ? -
the generated files (all of them) are enough if you have set the parameters correctly
Thanks i still dont understand why there is not a tutorial like with pictures how to for a noob like
thanks again everyone
@Petar, sorry - I didn't fully digest your question in that it was pertaining strictly to the online config tool. If you get stuck, give a look at pages 18 and up - these were my lessons learned with getting bltouch operating.
Cheers,
Kolbi -
what do you mean by pages 18 and up ?
do you have a link for me ?
thanks -
@Petar, my first post had a pdf attached.
@Petar said in bltouch config:
I also posted a 5 part guide on getting an ender 3 up and running with a maestro on RRF2. It's not exactly the same as the wifi on RRF3 but a lot is applicable.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
At some point you'll have to climb the mountain of learning.
@Kolbi
i missed that thanks -
Ok will read that thanks
@Petar, no worries at all. Hope you get it working!
@Kolbi
Yes I hope so too, I am very curious how much better this is than Marlin and the Chinese cheap ass boards -
Maybe this will help. BL Touch guided install on Duet 2 Hardware.pdf
@Phaedrux Again I learn much from your experience, thanks!
@CaLviNx This is great! thanks!
@CaLviNx
Thanks man i'm learning a lot here
