    How to use New Mcode run Multiple Mcode?
    Gcode meta commands
    • jimmychiuundefined
      jimmychiu
      I want to create M6 code in Reprap.
      The codes is like bellow,
      G0 Y150
      G0 Y225
      G0 Y150
      And need wait active finish and run next.
      How to do?
        jay_s_uk
        Do you realise that if you want to us a gcode that isn't supported that you can create a file called M6.g and put it in the sys folder?
        You can then add whatever you want to the contents of that file and when M6 is called it will execute that file?
          jimmychiu
          Yes,I know. But, g file can not put any parameter, right?
          I need m code like M19 A300 B200 C400.
          Now, I need call other existed m code.
            jimmychiu
            example,
            I want run M6 A10 B20 C30 , action like bellow picture.
              jimmychiu
              Anyone knows what my question? I want to run G83 in CNC machine.
              I just want to know how to add mutiple G/M code in G83 code.
                It's not currently possible to pass parameters to macro files. Support for macro parameters is planned for firmware 3.3.
