    Fans not working Duet 2 wifi
    317
    • budlightundefined
      budlight
      I just bought a duet 2 wifi to use on my CR 10 mini and I cannot get my hot end and part fans to work. I first tried plugging them into the always on port and that didn't work and then I tried fan 0 and 1 and still nothing. The jumpers are on the vin and V_fan
      • Vetiundefined
        Veti
        check the fuse.
        did you get the polarity correct? if the fans are plugged in the wrong way it can damage the duet.
        budlightundefined 1 Reply Last reply Reply Quote 0
        • jmshepundefined
          jmshep
          I had a strange incident of a fan not working recently. The cooling fan on my hot end stopped working after running ok for some time. I took it off and connected it to an external power supply and it worked fine. I tried it on an 'always on' connection on the Duet and it still did not work. Fitted a new fan and it now works as before. I do not know what has gone wrong with the old fan for it to stop working with the Duet board.
          • budlightundefined
            budlight @Veti
            @Veti yes
            • budlightundefined
              budlight @jmshep
              @jmshep I've tried multiple fans to check. The only thing that I haven't tried is to check the resistance, continuity, and programming.
              • Vetiundefined
                Veti
                does the fan spin if you connect it directly to the power supply that is connected to the duet?
                budlightundefined 2 Replies Last reply Reply Quote 0
                • budlightundefined
                  budlight @Veti
                  @Veti yes it does.
                  • budlightundefined
                    budlight @Veti
                    @Veti im going to check the resistance and continuity tomorrow
                    • jmshepundefined
                      jmshep
                      Don't forget that the fans used for this application are usually 'brushless' and you will probably get a very high reading with the probes connected one way and infinity when connected the other way round.
                      BTW my fan issue turned out to be a connector problem.
