Cannot initialise SD card
I have already followed this procedure: https://duet3d.dozuki.com/Wiki/SD_Card nothing.
what happend to the original sd card that came with the duet? did it fail?
Yes. her and the other two cards I bought.
sd card slot broken. need to be replaced I think
Okay, how do you do this delicate operation.
If you have a hot air soldering station, it's easy
I'm kidding at the price a Duet3D motherboard costs, I'm not going to do any soldering since it's still under warranty.
When and where was the Duet purchased? If within 6 months from an authorized reseller it would be covered under warranty.
Just to confirm, you've tried 3 different SD cards and none are able to be read?
@Phaedrux
I bought it on June 04, 2020 on the E3D-Oline website. I confirm 3 sd cards and none worked and followed the recommendations of the link: https://duet3d.dozuki.com/Wiki/SD_Card. -
@jbfrancois Please contact E3D to initiate a warranty exchange. Include a link to this forum thread as authorization.
I have opened a ticket to E3D-Online support and to activate the warranty, certain conditions must be met, including the following :
- If Duet confirms that it is a fault with their product they will do so on the post, please note that this will need to be a Duet Admin that confirms the need for a replacement.
Do you confirm this ?
Phaedrux already did that.
@Veti
Thank you for your answer -
Yup, you're good to go.
