Timelapses, are they possible?
do you have the timelapse python script running multiple times?
reboot the pi and make sure to not start it more than once.
it's probably easier for debugging to remove the autostart and enter the command into putty directly. -
@resam said in Timelapses, are they possible?:
it's probably easier for debugging to remove the autostart and enter the command into putty directly.yes you're right it's running twice I'm afraid, once for the autostart and maybe the second when I log in?
if you used /etc/profile or .bashrc, then yes - this will likely cause multiple starts.
ok, I leaved from profile ad rebooted pi
as before
Have you got an idea about the problem?
it's probably easier for debugging to remove the autostart and enter the command into putty directly.Good morning....I've tried to understand what could be the problem reading the script but Phyton is over my knowledge...could you help me? Thanks!
I've tried to use this as well: https://dr-b.io/post/Duet-3D-Printer-TimeLapse
But it doesn't work for me because of a parsing error with the JSON given by the Duet webserver I suppose...I can't contact the author of the procedure (my questions haven't been moderated yet)....does anyone use this? In case not does anyone know if in the latest version of the Duet webserver somehing has been changed in the JSON mentioned in the above link?
Thanks
Andrea -
have you tried Danal's version?
https://github.com/DanalEstes/DuetLapse -
@jay_s_uk said in Timelapses, are they possible?:
https://github.com/DanalEstes/DuetLapseno, not yet
That handles both versions of responses from RRF
I'll give it a try so! Thanks for he advice
a mess...:
I'm the author of https://github.com/kriechi/DuetRRF-timelapse - Ask me Anything
Generating timelapse videos is quiet an opinionated topic in 3D-printing - everybody has a slightly different setup and preferred way of doing it. This is how I currently run my printer setup:
There are two things needed to make print-synced timelapses:
- your slicer needs to insert the
M118
commands on every layer change - your raspberry pi needs to run the timelapse.py script
You need to enable Telnet support in your Duet board with
M586 P2 S1
You can start the timelapse script on your RaspberryPi like this:
./timelapse.py some-folder-for-all-images/ 192.168.1.42 http://127.0.0.1:8080/?action=snapshot
(with the IP address of the Duet printer, and the URL is in my case mjpg-streamer returning a single jpg image)Hi, I've seen that you have updated the scripts and I've installed them....following the instruction nothing works, tho enly way to make it take snapshot is, on putty, to insert manually the command:
python3 /usr/local/bin/duet_timelapse.py /home/pi/timelapse_tmp 192.168.1.7 "http://192.168.1.13:8081?action=snapshot"
but in this way it captures the snapshot but doesn't produce the final rendering...without python3 it doesn't work at all, so I've changed duet_timelapse.service in this way:[Unit]
Description=Duet Printer Timelapse
Wants=network-online.target
After=network-online.target
StartLimitIntervalSec=0[Service]
ExecStart=python3 /usr/local/bin/duet_timelapse.py /home/pi/timelapse_tmp 192.168.1.7 "http://192.168.1.13:8081?action=snapshot"
User=pi
Group=pi
Restart=always
RestartSec=1s
Environment=PYTHONUNBUFFERED=1[Install]
WantedBy=multi-user.targetbut it doesn't work, I've tried to insert python3 /usr/local/bin/duet_timelapse.py /home/pi/timelapse_tmp 192.168.1.7 even in crontab but it doesn't work....what am I missing?
You should not need the
python3 ...
prefix.
What doessystemctl status duet_timelapse.service
say? -
Nope - "auto-restart" means it crashed somewhere...
What does
journalctl -t duet_timelapse.service
say? -
Whats your current
ExecStart
line? I think you might have messed around with it a bit too much -
Whats your current
ExecStart
line? I think you might have messed around with it a bit too muchuh surely, how can I see the ExecStart?
@the_dragonlord said in Timelapses, are they possible?:
Whats your current
ExecStart
Thanks for everything....it didn't create the video at all
I've pushed another update - turns out I had the ffmpeg option disabled instead of enabled.
With the latest update you need to pass in this extra command line argument:
--run-ffmpeg
