    M21 Error: Code is not supported
    DSF Development
    • ofliduetundefined
      ofliduet
      I'm getting this error response from a Duet 3 with SBC. Is this due to the SD "card" being a directory on the SBC, which doesn't need initialising? The gcode documentation or forums do not give any hint on why this code is not supported (any more).
        jay_s_uk @ofliduet
        @ofliduet because the sd card when in SBC mode is virtual.
        M21 etc is still supported in standalone
        • ofliduetundefined
          ofliduet
          I suspected as much. It might be worth keeping it around for backwards compatibility. Currently the error response breaks Octoprint.
            I agree, M21 for SD card 0 should just return success when running with SBC. One for @chrishamm.
            • chrishammundefined
              chrishamm administrators
              Thanks for pointing this out, I'll change DSF so M21 doesn't return an error message for SD card 0 (which is the default for M21).
              Duet software engineer
