    Pulley VS belts
    1.2k
    • fcwiltundefined
      fcwilt @Rudy2A
      @Rudy2A said in Pulley VS belts:
      @fcwilt said in Pulley VS belts:
      Très heureux avec les resultats.
      Hi Frédéric, This is exactly what I want to do ... I want to put three independent belts each with their own motor (in a triangle position on the bed frame) with the automatic leveling ... Do you have a demonstration of your printer? Thank you
      I assume you are talking about a video? I certainly can make up a quick one if you like.
      I included an end stop sensor on each Z axis which handles the bed if it is grossly out-of-level.
      Then the auto level feature finishes the job.
      Rudy2Aundefined 1 Reply Last reply Reply Quote 0
      • Rudy2Aundefined
        Rudy2A @fcwilt
        Salut,
        Je suppose que vous parlez d'une vidéo? Je peux certainement en inventer une rapide si vous le souhaitez.
        J'ai inclus un capteur de butée sur chaque axe Z qui gère le lit s'il est grossièrement hors de niveau.
        Ensuite, la fonction de mise à niveau automatique termine le travail.
        Frédéric
        Indeed I would like to see the result on video, but I don't want to disturb you! Did you create your printer by taking a model or plan from the internet or did you create it according to your own plans and ideas?
        • fcwiltundefined
          fcwilt @Rudy2A
          It all started with purchasing the parts needed to build a DBot. I didn't like the initial design and re-worked things a few times.
          Then I got the urge to try a MarkForged type printer. I liked that basic design and it hasn't changed much at all.
          What has changed is several approaches to the Z axis system.
          This is what the current printer is like using the three Z steppers with gearboxes and belt drive.
          Once I discarded the initial DBot design everything since it is all my own.
          I'm pleased with it but am planning a few changes because the first steppers I purchased appeared to have a 5-to-1 gearbox until you checked the fine print - they are actually 5.18-to-1. But they were inexpensive so I started with them.
          I now have the units with the true 5-to-1 gearboxes but am waiting on some pulleys.
          Rudy2Aundefined 1 Reply Last reply Reply Quote 2
          • fcwiltundefined
            fcwilt
            I'll make a video tomorrow (Thursday) and post it here.
            Turboundefined 1 Reply Last reply Reply Quote 2
            • Turboundefined
              Turbo @fcwilt
              @fcwilt
              This is my build. uses a belted z axis and linear rails for the z axis. this pic shows rollers, but ive since updated it, and alot of other things. works really well with a planetary gear reducer one a single nema 17 motor.
              Cant stop tuning wont stop tuning.
              Dbot, Custom i3, Voron 0&2
              • fcwiltundefined
                fcwilt @Turbo
                @Turbo said in Pulley VS belts:
                @fcwilt
                Did some of those parts come from the DBot design?
                Turboundefined 1 Reply Last reply Reply Quote 0
                • Turboundefined
                  Turbo @fcwilt
                  @fcwilt referring to the z axis? no not really, besides the bed and its frame. but id be happy to share the cad files if that's something you're looking into. the rest of the build is pretty standard dbot, aside from gantry being dual extruder
                  • fcwiltundefined
                    fcwilt @Turbo
                    I was referring to the parts supporting the X gantry.
                    • Turboundefined
                      Turbo @fcwilt
                      @fcwilt yes. with some slight modifications that wouldnt change anything. i also have a linear rail compatible version.
                      • Rudy2Aundefined
                        Rudy2A @fcwilt
                        @fcwilt Thank you. Sounds well thought out!
                        • fcwiltundefined
                          fcwilt @Rudy2A
                          I just noticed that the image I posted was an out of date one.
                          I have updated the image.
