    Duet 6HC from SBC to Stand Alone?
    Firmware installation
    906
    • blt3dpundefined
      blt3dp
      Just wanted to make sure it wasn’t inadvisable.
      My 3D Printing YouTube Channel
      Better Living Through 3D Printing
      Follow me on Instagram and Twitter
      Instagram
      Twitter
      • blt3dpundefined
        blt3dp
        From what I understand, the only option to connect paneldue 7i to duet 3 is the 4 pin and I cannot use the ad card on panel due?
        Instagram
        Twitter
          Phaedrux Moderator @blt3dp
          @blt3dp Correct.
          • blt3dpundefined
            blt3dp
            Got the Panel Due 7i connected and I can control the printer. I thought it was now able to show the macros on the virtual sd card of the sbc.
            Firmware on the panel due is 1.23.2
            Edit: Updated the Panel Due Firmware and it's good now.
            Instagram
            Twitter
            • blt3dpundefined
              blt3dp
              Doesn't look like I can start a print from the Panel Due though. I click the SD card icon and it shows nothing there. I'm guessing cause it's thinking about the one that's on the panel due?
              Instagram
              Twitter
                @blt3dp I think it should default to the internal SD card, but there's a button that has an SD card icon that should let you cycle between.
                Do you have anything in the gcodes folder on the internal SD card? Do things show up there in the DWC?
                • blt3dpundefined
                  blt3dp
                  I hadn't planned on doing it right now, but I ended up migrating from the SBC to Stand Alone and it works.
                  I also did have another question,
                  I've had to move the printer to a room without ethernet. Aynone have any good recommendations or a wireless bridge that I might plug into the ethernet of the Duet 3?
                  I'd like to power it via a 5v psu that I already have hooked up.
                  Instagram
                  Twitter
                    A Former User @blt3dp
                    @blt3dp you can use the pi unless you have a different use for it. sudo snap wifi-ap (or maybe that was for the ubuntu stuff, ask google and you'll find solution with and without NAT as needed)
                    • blt3dpundefined
                      blt3dp
                      I think I found an old article that pointed to a TP Link Nano Router that can also be a bridge as well as others. It's inexpensive, looks to do what I like.
                      I'd prefer not to use a pi at this point.
                      Instagram
                      Twitter
                        @blt3dp fair enough. inexpensive and gets the job done is a winner.
                        if you have other wifi hardware lying around, seeing if they're supported by openwrt (or if cheaper available hardware is supported) could also be an option.
                        being a bridge is usualy just a software option, so replacing the software enables 99% of all consumer routers to become a wifi bridge.
                        blt3dpundefined 1 Reply Last reply Reply Quote 0
                        • blt3dpundefined
                          blt3dp @A Former User
                          I got a TP Link Nano Router and set it up in client mode. It automatically disables its onboard dhcp server and passes the requests through to the one provided by my router. Looks just like a wired Duet 3 to it.
                          https://www.amazon.com/dp/B00TQEX8BO/ref=cm_sw_r_cp_api_fabc_eewVFb2DGTHWN?_encoding=UTF8&psc=1
                          Instagram
                          Twitter
                            @blt3dp That's a good price. They have really come down a lot.
