    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.8k
      A Former User @jay_s_uk
      @jay_s_uk said in 3D GCode Viewer integrated with DWC:
      @the_dragonlord what version DWC are you running?
      the latest beta
        A Former User @A Former User
        @the_dragonlord I've reinstalled it and now it works like a charm, sorry guys!
        Sindariusundefined 1 Reply Last reply Reply Quote 1
        • Sindariusundefined
          Sindarius @A Former User
          @the_dragonlord glad you got it going!
          • Exerqtorundefined
            Exerqtor
            This post is deleted!
            • neetspeedundefined
              neetspeed
              Hello
              it works on duet 2 wifi
              thank you
                A Former User
                  A Former User
                  Hi...I'm realizing I'm the man of the "strange-things"...in my PCs (I've tried 2) the plugin seems to work in "opposite way"....when a layer starts it shows me the entire layer itself and so the nozzle prints the printed parts disappears from the view:
                  Layer beginning:
                  Same layer after few lines:
                  as you can see the printed section "disappeared" from the draw. I've tried almost all the combination for the settings but nothing seems to work...As you can see it shows me only the current layer.
                  Here are my whole seettings:
                  What am I doing wrong?
                  Sindariusundefined 1 Reply Last reply Reply Quote 0
                    @the_dragonlord This may actually be a bug due to a recent change I made on how the colors set up the viewer. The alpha channel used to be configurable on those fields but I removed that since it more often than not caused trouble. But it looks like now it is setting the alpha of the printed area to 0. I'll have a fix for this put up in a few minutes.
                      A Former User @Sindarius
                      @Sindarius excellent! thanks
                        @the_dragonlord https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.9.3
                          @Sindarius said in 3D GCode Viewer integrated with DWC:
                          sooooooooooooooooooooooooo much better! It works like a charm now!
                            @the_dragonlord excellent, I plan to put together documentation at some point for all the settings.
                            • Exerqtorundefined
                              Exerqtor
                              @Sindarius Is it possible to make the plugin "forward" compatible? I just updated toDWC 3.2.0b4 and then it won't let me install the plugin (it want's me to run 3.2.0b3).
                                Sindarius @Exerqtor
                                @Exerqtor I’ll look into it. I thought it would be forward compatible. Worst case pull down the zip and in the plugin.json change the version. The only real requirement was the context menu feature that was added to 3.2 b3
                                • Exerqtorundefined
                                  Exerqtor
                                  Yeah me to, I've done it allready 😃
                                  Maybe it dosn't recognize the "-b4" as a newer release than "-b3" and only the pure nummerical part is what determines it? (on the DWC plugin handeling side i mean).
                                  • DaBitundefined
                                    DaBit
                                    Updated to DWC 3.2-b4, downloaded the plugin, changed the version in plugin.json from beta3 to beta4, and it seems to install.
                                    I am not seeing the plugin in the 'plugins' list under Settings->General->Plugins however, only the Duet3D G code visualiser, height map, object model browser and onscreen keyboard.
                                    After installation there is a GCodeViewer directory in the www/ directory on SD card with GCodeViewer.40d6d65b.js and GCodeViewer.2033367e.css file in it.
                                    • chrishammundefined
                                      chrishamm administrators @Sindarius
                                      @Sindarius It should be possible to make it forward compatible by changing dwcVersion in the plugin manifest from 3.2.0-beta3 to 3.2.0 but I cannot recommend that yet since the API may be changed again in the next DWC release.
                                      Duet software engineer
                                      Sindariusundefined 1 Reply Last reply Reply Quote 2
                                        Sindarius @DaBit
                                        @DaBit you need to go to machine settings and third-party plugins will appear there.
                                        • DaBitundefined
                                          DaBit
                                          @Sindarius : thanks, that works.
                                          A bit weird that there are 2 plugin-enable-locations.
                                            Sindarius @chrishamm
                                            @chrishamm Since beta 4 is out I will update my plugins to reflect the latest beta. Only takes a few seconds to change.
                                            I don’t want to call out 3.2.0 at this point because I do depend on the right click context menu feature in jobs that was introduced in beta 3.
