    Email/notifications from Duet wifi
    Duet Web Control
    10
    21
    2.1k
    • Danalundefined
      Danal
      Why not just write a "send email" capability into the Printer? Because that would (more or less) require the printer to contact a web IP address. Bad, bad juju to have IOT devices like printers open anything to the internet.
      Also lack of flexibility. There are dozens, if not hundreds, of notification services. The printer firmware would always be lacking some specific interface.
      MQTT from printer to broker, broker is the one handling internet stuff, and can probably interface to almost anything, either built in, or via command line. Much better juju.
      • r123undefined
        r123
        I thought ssl smtp access was just a single port?
        An IOT gadget can’t be made “broadcast only” (thus safe) in its internet access?
        • Danalundefined
          Danal @r123
          @r123 said in Email/notifications from Duet wifi:
          Safe is relative. Better that a firmware based device have absolutely zero direct connectivity. In, out, whatever.
          But really, the much bigger reason is... what list of things to support from the firmware? "Just" SMTP?? What about SMTP with authentication? (there are VERY few open mailservers around anymore). With TLS? or some other encryption? or MAPI (a much more secure mail protocol)? Or...
          MQTT for IOT devices. MQTT broker to do anything you want.
          • Nightreaverundefined
            Nightreaver
            @dc42 Is there any update on the MQTT progress?
            Will it be available with RRF 2 or only with the new RRF3 ?
            Will it publish all information from the WebIF? Like temps, speed, job status etc?
              dc42 administrators @Nightreaver
              @Nightreaver said in Email/notifications from Duet wifi:
              Not yet.
              I will not be adding any new features to RRF2.
              No, just "major event" messages. Other devices can use HTTP requests rr_status and rr_model to get the data they want.
              • Lanovarundefined
                Lanovar
                @dc42 said in Email/notifications from Duet wifi:
                Not yet.
                @dc42 Any news on that? 🙂
                  Nightreaver
                  For those who are interested...
                  I took a similar solution for MQTT and adapted it to duet3d api endpoint.
                  It works fine so far as im using it for myself, tho not all options for MQTT publishing are implemented yet.
                  Feel free to try it and report bugs.
                  https://github.com/Nightreaver/RRF_WebIF_MQTT
                  • alankilianundefined
                    alankilian
                    I'll definitely try this mid-December after my current printing set is complete.
                    One thing: In my MQTT experience, it's a good idea to have a topic like "State" where you set the last-will to publish with retain a payload of "Offline" and then in the connect routine, publish a payload of Online" with retain.
                    That way, you can check the state easily without looking at any other topics.
                    I see you have a last-will set, but I'm not familiar with those three systems, so I don't know if that's the by-the-book way to use last will. If so, ignore me.
                    Also, it's also good to have a unique device ID in the topic so many devices can all publish to a broker and you can weed them out by which topics you subscribe to.
                      Nightreaver
                      I see, thats what LWT means! I will check up on that topic, thanks
                        alankilian @Nightreaver
                        @Nightreaver Cool.
                        You can contact me anytime for MQTT-related discussions.
                        I spent 4 years doing commercial MQTT implementations on tiny microcontrollers and have tens of thousands devices in the field talking all day long.
