    Duet 2 Wifi Perimeter Gaps
    • Tommygunzundefined
      Tommygunz
      Hello. For some time, I've been struggling with a minor print quality issue with my printer. With every print, there are gaps between the perimeter and infill, mostly in the X direction (seems like the inner two perimeters are offset from the third). I tried: tuning my slicer (Simplify3D), calibrating extrusion and X/Y steps, playing with belt tension, installing a new X axis belt, modifying my X carriage so it slides smoother, swapping X and Y axis motors, enabling pressure advance. I know it is not my slicer because my bone stock Ender 3 with the same settings does not have this issue. The print comes out great! Im not sure if the issue lies within my firmware.
      ![0_1607113585228_AM8 DUET PETG OVERTURE.fff](Uploading 100%)
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X100.78 Y100.67 Z397.27 E414.69 ; set steps per mm
      M566 X500.00 Y500.00 Z150.00 E1500.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X8400.00 Y8400.00 Z250.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X650 Y650 Z650 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-34 Y-10 Z0 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
      M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
      M558 P9 C"^zprobe.in" H5 F100 T2000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X20:210 Y20:210 S30 ; define mesh grid
      M950 S0 C"exp.heater3"
      G31 X53 Y6 Z2.898 P25
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S130 ; set temperature limit for heater 0 to 130C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S70 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q50 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S150 H-1 ; set fan 2 value. Thermostatic contol is turned off
      M572 D0 S0.3 ; Enable pressure advance
      T0 ; select first tool
      M501
        Tommygunz
        Also using Overture PETG at 240 print temp, 80 degree heat, 40mm/s print speed.
          Probably printing too fast or too cold or too much fan causing delamination
          • Vetiundefined
            Veti
            @Tommygunz said in Duet 2 Wifi Perimeter Gaps:
            how did you arrive at those numers?
            its likely that you have a lot of backlash in the y direction, that can cause the issues you are seeing.
            grab the nozzle while cold and the motors energiezed. with your fingers see how much you can deflect the nozzle in each direction without using excessive force.
            since you have a bed flinger, do the same for the bed. move it back and forth and see how much play there is.
            Tommygunzundefined 2 Replies Last reply Reply Quote 0
              Tommygunz @Veti
              @Veti I got those values from the calibration cube test. Ill check out the free-play of the X and Y axis.
                Tommygunz @Veti
                @Veti I tightened everything up. No difference at all. Closely watching my printer, it seems like it stops short when printing the first two perimeters hence the large gap. Im not sure what else to try.
                • Vetiundefined
                  Veti @Tommygunz
                  thats not a good way to go.
                  you dont know if this comes from the play in your system or the actual steps.
                  you need to print 2 calibration cubes to verify.
                  one normal size one 300% the size.
                  you can only adjust of the error is 3 times going to the big cube.
