    BLTouch + Duet Wifi
    4.2k
    • ThePigSlayerundefined
      ThePigSlayer
      Thanks for the correction hendricks.
      You can setup macros but you will also need to edit the retract and deploy system files as those are what m402 and m401 call.
      Anyways, here is my bed.g file, which I call by just clicking the auto bed compensation button, or G32.
      M557 X50:150 Y50:150 S25    ; Define grid
      T0                          ; Select tool 0
      G91 			    ; Relative mode
      G1 Z10 F150		    ; Make sure everything clears the bed
      ; ------------ Home Z ---------------------
      G90                         ; Absolute mode
      G1 X110.5 Y72 Z6 F4000      ; Home at center of bed, my offsets are X-10.5 and Y28
      M401                        ; Deploy probe
      G30                         ; Home Z-axis
      ;----------- Mesh Level ------------------
      G29                         ; Start mesh level
      M374                        ; Save results, but this might not be necessary
      M402                        ; Retract probe
      G1 X20 Y20 Z10 F3000        ; Dock position
      • FrankNPrinterundefined
        FrankNPrinter
        I am settting up my bl touch now. appears to be wired and working correctly i jest can't seem to find where to enter the off set for the probe vs print head. Can someone please refresh my memory?
          FrankNPrinter
          Thank you sir! just what i was looking for! stand by… 🙂
            FrankNPrinter
            this is a cartesian. FT5 bl touch classic Here are my config files. I had the bl touch for months and started setting it up but was an even more of a newbie then then i am now. been doing manual level and printing fine for months. I found and copied a lot of above for the other files in this thread (thanks much to all above!!!) but i think cut and paste is not the best way to go about it. Everything appears to work and i can power up and home fine but when i try to bed level via auto compensation button or macro, probe deploys then print head shoots to front right corner of machine and bl touch is solid red so no apparent error. I know something is not right but no idea what. offset on x is 22 mm and doc indicates max is 15mm so not sure if that is a hard limit. probably just a mismatch from configs above… Any help in cleaning up my config would be much appreciated!
            "Config G"
            ; BLTouch
            M307 H3 A-1 C-1 D-1
            M558 P5 X-22 Y-9 Z4 H3 F200 T5000
            "Deployprobe.g"
            M280 P3 S10 I1 ;deploy probe might need to try no I1
            "Retractprobe.g"
            M280 P3 S90 I1 ; retract probe might need to try no I1
            "bed.g"
            ; Clear any bed transform
            M561
            ;# Deployprobe.g
            M280 P3 S10 I1
            ; Probe the bed at 5 points
            G30 P0 X50 Y50 H0 Z-99999
            G30 P1 X50 Y250 H0 Z-99999
            G30 P2 X250 Y250 H0 Z-99999
            G30 P3 X250 Y50 H0 Z-99999
            G30 P4 X150 Y150 H0 Z-99999 S
            ;#Retractprobe.g
            M280 P3 S90 I1
            meshlevel.g
            ; called when tool 0 is freed
            meshlevel.g
            T0 ; Select first hot end
            G91 ; Relative coordinates - for dropping Z no matter what its current height
            G1 Z4 F6000 ; Lower bed to avoid hotend dragging in bed.
            G28 Y ; Home Y axis first to avoid crash
            G28 X ; Home X
            G90 ; Absolute coordinates
            G1 X50 Y50 F3000 ; Go to first bed probe point and home the Z axis
            G28 Z ; Home Z given we are in a known safe on-bed position
            M557 X10:250 Y10:250 S40 ; Bed probe from X50 to 220 and Y50 to 220 in 40mm increments
            M401 ; Lower BLTouch probe-refrences deployprobe.g
            G29 S2 ; Clears bed height map in RepRapFirmware
            G29 ; Kicks off the Z probing across the height map
            M402 ; Retract BLTouch probe refrences probretract.g
            M374 ; Save calibration data. Default is sys/heightmap.csv
            G1 X10 Y10 F3000 ; All done - move to BACK right
            ;Still playing with mesh stuff. Also note that for some reason sending simple probe code g29 or g30 will result in a crash into hotend.
            ;Using those codes does not include deploying probe M401.
            ;So I just made a macro for meshprobing so I can do it from the machine with out web service.
            Meshlevel macro
            G28 X ; Home X
            G1 X10 Y10 F3000 ; Go to first bed probe point and home the Z axis
            M557 X10:220 Y10:250 S40 ; Bed probe from X10 to 220 and Y10 to 185 in 40mm increments
            M402 ; Retract BLTouch probe refrences proberetract.g
              FrankNPrinter
              update. did some testing and these 3 commands appear to work fine so assumeing config files are fubar
              M280 P3 S20 I1; test mode
              M280 P3 S10 I1 ;deploys probe
              M280 P3 S90 I1 ; retracts probe
              • AaronGreenundefined
                AaronGreen
                I'm still not 100% on the calibration because I don't have a conclusive idea of the config information.
                If we're all using a BLTouch with the DuetWiFi, every bit of information should be the same except the bed size and carriage height parameters.
                Currently, my Auto Home process checks X and Y, then when the probe touches the bed it sets off the Alarm and rams the bed indefinitely.
                M111 S0 ; Debugging off
                G21 ; Work in millimetres
                M555 P2 ; Set firmware compatibility to look like Marlin
                M208 X340 Y250 Z280 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
                M558 P5 X0 Y0 Z1 H5 F200 T6000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
                G31 X-40 Y7 Z0.9 P1 ; Set Z probe trigger value, offset and trigger height
                ;Z-offset (Z0.9). Higher value LOWER nozzle height
                ; Lower value RAISE nozzle height
                M557 X10:340 Y10:240 S68 ; Define mesh grid
                M307 H3 A-1 C-1 D-1 ; disable heater 3, which makes it available for use to control the BLTouch
                M569 P0 S1 ; Drive 0 goes forwards - X
                M569 P1 S0 ; Drive 1 goes backwards - Y
                M569 P2 S0 ; Drive 2 goes backwards - Z
                M569 P3 S1 ; Drive 3 goes forwards - Extruder
                M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation 16
                M92 X160 Y160 Z1600 E800 ; Set steps per mm 16
                M566 X600 Y420 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) - (JERK)
                M203 X6000 Y6000 Z500 E400 ; Set maximum speeds (mm/min)
                M201 X1000 Y1000 Z1000 E250 ; Set accelerations (mm/s^2)
                M204 P1000 T1000 ; Set Max acceleration for P=printing moves and T=travel moves
                M906 X1600 Y1600 Z900 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M143 S285 ; Set maximum heater temperature to 285C
                ;M305 P1 X101
                M305 P1 T107000 B10832 C4.891620e-7 R4700 ; Set thermistor + ADC parameters for heater 0 - BED
                M305 P0 T99600 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1 - HOTEND E3d
                M307 H0 P96.0, I3.285, D603.9 ;Bed
                M307 H1 P1.1, I0.011, D51.5 ;Hotend pid
                ;M307 H1 P17.8, I0.055, D74.9 ;Hotend E3d pid
                M563 P0 D0 H1 ; Define tool 0
                M550 CLU ; Set machine name
                M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                • Sniffleundefined
                  Sniffle
                  @AaronGreen:
                  ;M305 P1 X101
                  this does not show your homeall.g and homez.g, those files are what control your homing process, and most likely the procedure needs to be changed from the G1 command to lower indefinately to G30 which will amke it stop
                    AaronGreen
                    @Sniffle:
                    this does not show your homeall.g and homez.g, those files are what control your homing process, and most likely the procedure needs to be changed from the G1 command to lower indefinitely to G30 which will make it stop
                    This is what I have…
                    FYI. My set up also uses the Z probe connection for Z GND and IN. The rest are on Expansion Pin 1, 2 and 8 respectively.
                    I'm just on a 3D printer fixation at the moment because I've pushed back a major port folio gig for a props company I need to do a presentation for.
                    ; homeall.g
                    G91
                    ; Lift Z
                    G1 Z5 F6000
                    ; Course home X and Y
                    G1 X-235 Y-215 F4000 S1
                    ; Move away from the endstops
                    G1 X5 Y5 F5000
                    ; Fine home X and Y
                    G1 X-235 Y-215 F250 S1
                    ; Absolute positioning
                    G90
                    ; Go to first bed probe point and home Z
                    T0 ; select first hot end
                    G1 Z3 F200 ; Lower bed to avoid hotend dragging in bed.
                    G90 ; Absoulte coordinates
                    G1 X170 Y125 F3000 ; Go to first bed probe point and home the Z axis
                    M401 ; deploy probe
                    G30 ;probe
                    M402 ;retract probe
                    G1 Z2 F200 ; Raise bed to 2mm.
                    homez.g
                    G1 Z5 F200 ; Lower bed to avoid hotend dragging in bed.
                    M401 ; deploy probe
                    G30 ; Calibrate Z-axis
                    M402
                      AaronGreen
                      I also noticed that the Z probe sensor on the console doesn't show any changes when the probe rams the bed, or when the alarm goes on or off, or if the probe is triggered.
                      Maybe the signal from the probe isn't reaching the console or something…
                        AaronGreen
                        Found the immediate problem. Rookie mistake. I checked the colouring of the BLT ground wire and it changed from black to blue when it went through the Tevo connector to the board, which meant the Z probe wires were switched.
