    Panucatt Kinetica G2C
    Other control boards
    756
    • oliofundefined
      oliof
      Hey,
      someone asked me about a new control board running RRF, the panucatt kinetica G2C. Has this been developed in cooperation with Duet3D or is it just a random board that happens to use RRF? I also wonder about the TMC2209s they use -- I guess with stock RRF those would run like 2208s, so without all the interesting 2208 features?
        Phaedrux Moderator @oliof
        @oliof said in Panucatt Kinetica G2C:
        explicitly not linked directly because I don't know what the policy is on third party products
        No issues linking unless it's commercial spam.
        • oliofundefined
          oliof
          raises thread from the depths
          I finally acquired the G2C and did a dry run over the weekend.
          The board is a drop in replacement for the ender3 control board. It also allows dual z with a shared stepper driver.
          Firmware is still some 2.05RC1R1 build that I couldn't find the source for.
          The board is limited to 3m3v endstops and proves. It also doesn't sport any connectors beyond what's needed on the ender3.
          An interesting feature is the socket approach for the WiFi and Ethernet modules, which would make it simple to adapt for the upcoming SBC mode for non duet3 boards ... if RRF3 would be ported over
          While personally I am a bit disappointed that there are no additional pins and headers, i.e. for a dual nozzle setup, additional fans, or similar, the board is advertised as a drop in replacement for the Ender3, and it fills that role.
          clue3030undefined 1 Reply Last reply Reply Quote 1
          • clue3030undefined
            clue3030 @oliof
            @oliof how did you set it up. Didn’t come with any instructions at all.
            gd81nundefined 1 Reply Last reply Reply Quote 0
            • oliofundefined
              oliof
              I sold it off, since I didn't have a use for it. In an Ender3 style machine it's pretty straightforward. Their fork is at https://github.com/Panucatt/RepRapFirmware and since it's still RRF 2.0.x you don't need to know the pin names.
              I can ask the person I sold it to whether they would share their configuration.
              • oliofundefined
                oliof
                Default config can be found in the support files https://panucattdevices.freshdesk.com/support/solutions/articles/1000287677-support-files
                • gd81nundefined
                  gd81n @clue3030
                  Look up Chris's Basement on youtube.
                  That and the links from Panucatt I've got mine going fairly well at the moment.
                  Can Share my config.g if you'd like.
                  • sinned6915undefined
                    sinned6915
                    Look in the alternative boards/ports section of the forums.
                    There is an STM port there I think.
