    Crimp pins for stepper on Duet3 6HC mainboard
    • medicusdkfzundefined
      medicusdkfz
      Hi everyone,
      I am running out of crimp pins for converting my Voron 2.4 with a Duet3 6HC from 1.8° steppers to 0.9°. Where can I get them in Germany? Does anyone have a link?
      It would be great if there would be replacement bags from the manufacturer at the dealers. In the case of a conversion, one has this problem in any case...
      Thank you,
      Pierre
        droftarts administrators @medicusdkfz
        @medicusdkfz See here for a list of Duet 3 connectors: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Duet_Num_3
        I think you want the VH396T-L crimps. These should be widely available, though not sure exactly where in Germany! The '-L' is for 'loose', so delete that to search for them on the reel, if that's what you need.
        • Vetiundefined
          Veti
          not sure but they are listed as jst vh
          https://www.reichelt.de/de/de/index.html?ACTION=446&LA=3&nbc=1&q=jst vh
            medicusdkfz
            I've found them already. It's the same link...
            Thank you,
            Pierre
