    No Connection after Updating DuetWiFiServer-1.25b0.bin
    Firmware installation
    822
    • Adamfilipundefined
      Adamfilip
      here is a video, might be helpful
      https://www.youtube.com/watch?v=VgzHchNEMX0link text
        A Former User
        Hard to tell from the exposure, but seems to be a lack of the green 3.3v LED (or possibly a clone, they usually have mostly red LED's - the sticker on the CPU seems to suggest repairs or a clone as well).
        please refer to https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_LED_indications and confirm wheather or not the 3.3v led is lit (regardless of colour)
        edit: if you're missing the 3.3v look closely at U2 (three pin device) just next to the temperature daughterboard, thats where 3.3v is made.
          Adamfilip
          This is not a clone. but its an early board.
          This one is On USB
            A Former User
            There is no 3.3v, so thats a problem. Both the cpu and the wifi module needs 3.3v to run.
            Before you start disconnecting everything, have a careful feel if anything is excessively warm - the remove endstops, z probe, daughterboard, sd card and see if the 3.3v led comes on
            edit: a477eb86-993c-4f20-8458-691b93b7bcdb-image.png
            that was the chip in question, no obvious damage so hopefully the fault is external
              As @bearer says, but in particular check whether any of the SD card socket, WiFi module, and main processor are excessively warm.
                Adamfilip
                The 3.3 Chip was very hot.
                nothing else seemed warm
                unplugged Bltouch, Daughterboard..
                When I unplugged the Endstops then the 3.3v light came on
                Looks like I had them plugged in incorrectly.. it currently has a 2pin connector from Ender 5, will change to hit th outside Enstop pins.
                I expect this will resolve it
                  Phaedrux Moderator @Adamfilip
                  @Adamfilip That's right, the Ender3/5 endstops will need to be re-wired to use the outside pins of the endstop connector.
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37#s119
                    A Former User
                    Ah, still interested in knowing if the usb connection that wasn't working starts working again once you've got the wiring sorted (unless that was the issue all along?)
                      Adamfilip
                      Rewired the endstops and yes now USB working fine
                      explains why it worked before i connected everything as well.
                        Adamfilip
                        So this resolves my ending issue. but doesn't really explain why it gave me problems to begin with. at that point the board was in my original machine.. same machine its been working fine in for 4 years. nothing new has been added for months.
