    Adding Camera Duet2 Wifi RSTP problems & Chrome
    Duet Web Control
    8
    30
    1.7k
    • uneumann36undefined
      uneumann36
      Hi Guys
      I got already very good help from you.
      So i will asked you if you has a solution to add a camera on Duet Web Control.
      I buy a wyze Cam V2 , and i already make new Software on it.
      So i have access to Camera via Chrome and typing ip into the browser.
      When i put the adress into Suet Web, i don´t get a Picture .
      Is there special settings to do?
      Hope someone can help me.
      • DIY-O-Sphereundefined
        DIY-O-Sphere
        I use the wyze Cam with dafang hack on my maestro...
        You have to add user and pw in the https-link
        Something like this: https://user:pw@xxx.xxx.x.xxx/cgi-bin/currentpic.cgi
        Check the wiki: https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control#Section_WyzeCamV2
        (UTC+1)
          uneumann36
          Thank you for your reply.
          I try this, but without function.
          Do i have to restart the Duet board?
            uneumann36
            Or are there other special settings on Duet Web ?
            Does it works with Chrome Brwoser?
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              DIY-O-Sphere @uneumann36
              @uneumann36
              I use Firefox
              Can you try to open the link (with pw+user) in a chrome tab. That should show you the still picture...
              (UTC+1)
                uneumann36
                Hi, Thank you for your reply.
                Yes this Works.
                  @uneumann36
                  Then you have to play around with the settings in the DWC tab. Uncheck fix frame and embedded.
                  (UTC+1)
                    Sadly, browsers no longer support RTSP. To get an IP camera to show up in DWC, it needs to have a facility to serve a still image.
                    DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                      DIY-O-Sphere @dc42
                      The wyze cam with modified fw has a build in rtsp-server.....
                      Mine is working with DWC.
                      (UTC+1)
                        DIY-O-Sphere @dc42
                        @dc42 said in Adding Camera Duet2 Wifi RSTP problems & Chrome:
                        You are right, as always. it's depending on browser.....Only working in firefox.
                        Does this mean that a service like "motion" is required for chrome ?
                        (UTC+1)
                          Probably, though there are alternatives to motion.
                          You might also be able to find a plugin/extension for chrome to bring back RTSP, but haven't tried it myself.
                            uneumann36
                            Thank you for all information.
                            So i am not a computer expert.
                            I play with this more then a week without function.
                            Does anybody know how to adjust my mofified Wyze Cam or Chrome Browser or DWC that this work?
                            May step by step?
                            Or is there no possibility to get this working?
                            Thank´s
                              uneumann36
                              It would be great if someone has an idea how to solve this.
                                What version of DWC are you using? Someone else just reported some problems in the recent betas as well.
                                  uneumann36
                                  Hi
                                  i use Duet Web Control 2.0.7
                                    Unfortunately I'm not familiar with the Wyze cams or how they are functioning, but since you are using an older DWC I would think that the methods posted above would still work.
                                    Have you tested in firefox to confirm if it's working there?
                                      uneumann36
                                      Yeah Firefox is also not working.
                                      • chrishammundefined
                                        chrishamm administrators
                                        RTSP isn't supported by modern browsers, so DWC doesn't support it either. You need to use mjpg or something else.
                                        Duet software engineer
                                          uneumann36
                                          Ok, sorry for the question,
                                          But how to do?
                                            uneumann36
                                            I hope someone has an idea
