    Duet 3 +SBC : Print randomely freeze when runin my script on RPI
    Beta Firmware
    1.0k
      Phaedrux Moderator @Donpi
      @Donpi said in Duet 3 +SBC : Print randomely freeze when runin my script on RPI:
      How can I switch to 3.2.0-b4.1 ?
      You'd have to switch to the unstable branch and then update.
      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
      • Donpiundefined
        Donpi
        It crash the print even with the 3.2.0-b4.1
        here is my M122
        M122
        RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956BA-NA3TN-6JTDG-3SD6J-TABLT
        Used output buffers: 4 of 40 (15 max)
        Static ram: 123292
        Dynamic ram: 137988 of which 36 recycled
        Never used RAM 130876, free system stack 188 words
        Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,49) MAIN(running,1161) IDLE(ready,19)
        Owned mutexes: HTTP(MAIN)
        Last reset 00:25:28 ago, cause: software
        Last software reset at 2020-12-09 15:50, reason: HeatTaskStuck, GCodes spinning, available RAM 130188, slot 0
        Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0x00000000 SP 0x20410144 Task MAIN
        Stack: 2042328c 00429512 81000000 00000000 3e958000 00000000 4079a000 401fc5e4 3f9ca0f0 4530c6d9 4530c6d9 44b0c6d9 49371b00 37533333 43d697a0 00000000 42117d81 3f800000 00000000 60000011 20426c58 2040e0b4 20426c58 00000000 20423af8 00000080 a5a5a5a5
        Error status: 0x00
        MCU temperature: min 35.1, current 37.4, max 37.6
        Supply voltage: min 24.8, current 25.0, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
        Driver 0: position 0, standstill, reads 12980, writes 14 timeouts 0, SG min/max 0/0
        Driver 1: position 0, standstill, reads 12981, writes 14 timeouts 0, SG min/max 0/0
        Driver 2: position 0, standstill, reads 12980, writes 15 timeouts 0, SG min/max 0/0
        Driver 3: position 0, standstill, reads 12981, writes 15 timeouts 0, SG min/max 0/0
        Driver 4: position 0, standstill, reads 12983, writes 14 timeouts 0, SG min/max 0/0
        Driver 5: position 0, standstill, reads 12987, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2020-12-09 16:16:44
        Slowest loop: 4.12ms; fastest: 0.12ms
        === Storage ===
        Free file entries: 10
        FreeDm 375 (min 375), maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        Telnet is idle in state(s) 0
        File* is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 6111, send timeouts 13750, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
        === SBC interface ===
        State: 0, failed transfers: 0
        Last transfer: 19ms ago
        RX/TX seq numbers: 15632/53872
        SPI underruns 0, overruns 0
        Number of disconnects: 0, IAP RAM available 0x209d8
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.2.0-beta4
        Code buffer space: 4096
        Full transfers per second: 1.96
        • Donpiundefined
          Donpi
          This post is deleted!
          • Donpiundefined
            Donpi
            The duet stop printing but the script continue
            • chrishammundefined
              chrishamm administrators
              Many thanks for reporting this, I've just reproduced and fixed this problem. It will be fixed in the next version.
              Duet software engineer
              • Donpiundefined
                Donpi
                Are there come log that I can check to see what is appening in the Duet ?
                Or what gcode is effetively executed .
                  There is this: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M929_Start_stop_event_logging_to_SD_card
                  And this: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                    TBH I had some problems with your plugin but I've got a fix ready - at least I haven't been able to reproduce it with the latest dev version. This problem only showed up when two G/M/T-codes from two different G-code channels were frequently sent.
                    To work-around this problem try to send your M106 code to the File channel (that's the same channel used for file prints) and consider adding a delay (e.g. await Task.Delay(1000);) after it. The second parameter of PerformSimpleCode lets you choose the target channel.
                    Donpiundefined 2 Replies Last reply Reply Quote 1
                    • Donpiundefined
                      Donpi @chrishamm
                      @chrishamm Great, I'll test that today.
                      I thought I was abandoned alone with my problem 👍
                      • Donpiundefined
                        Donpi @chrishamm
                        @chrishamm said in Duet 3 +SBC : Print randomely freeze when runin my script on RPI:
                        The workaround seems to work but it gives me many "Error parsing response" in the PanelDuet console
                          @Donpi I tested your plugin with 3.2-RC1 and I no longer get unexpected crashes or other problems. In any case I recommend adding a short delay once object model updates have been received to reduce the CPU usage a bit.
                          • Donpiundefined
                            Donpi
                            Good to hear that 😄
                            Thank you for the support
