    Duet 3 6HC micro SD socket damaged, need to send for repair
    Hardware dev
    1.2k
      You can test the endstop switches by sending M119 to see their status. Send it again when the switch is depressed to verify it's registered.
      To see the assigned IP address send M552.
      • supertb1undefined
        supertb1
        what string of code needs to be in the config file or how do I make the UI screen display the current IP address?
          Phaedrux Moderator @supertb1
          @supertb1 see my reply above
          • supertb1undefined
            supertb1
            yes I seen it thanks...lol... I appreciate your advise ... I also like the idea of making a Macro. I have a couple of other questions... on my Duet 3 board the reset button light flashes steadily and the panel Due 7 has connecting displayed on the top right hand corner... is this normal? also is there a advised source to learn how to program the UI so that I can can get things like the IP address and the limit switch inputs to display on the UI?
              @supertb1 said in Duet 3 6HC micro SD socket damaged, need to send for repair:
              Which UI do you mean? On the PanelDue or the web interface?
              You can create macros in the web interface and they would be accessible from the PanelDue or the web interface as well.
              Most gcode commands can be sent without any parameters and it will echo back the current values.
              Your PanelDue being stuck on connecting probably means that you're missing a command in config.g to enable it. You must have M575 P1 B57600 S1 for the PanelDue to work.
              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
              https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
              https://duet3d.dozuki.com/Wiki/Gcode
              Here are some example macros: https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3/macros
              • supertb1undefined
                supertb1
                When I say user interface I guess I am trying to convey the PanelDue... I would like to have all of the sensors display current statuses , again thank you very much for the advice.
                • supertb1undefined
                  supertb1
                  Could I have some one look at these G-codes in my config.g please
                  I am trying to set up for 2 Z motors, using Nema 23 motors and 3 pin limit switches. I am a bit of a noob so any advice would be helpfull.
                  • supertb1undefined
                    supertb1
                    ; generated by RepRapFirmware Configuration Tool v3.1.8 on Mon Nov 23 2020 22:57:12 GMT-0600 (Central Standard Time)
                    M550 P"Open Build Colosus" ; set printer name
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P0.3 S1 ; physical drive 0.3 goes forwards X
                    M569 P0.2 S1 ; physical drive 0.2 goes forwards Y
                    M569 P0.1 S1 ; physical drive 0.1 goes forwards Z1
                    M569 P0.0 S1 ; physical drive 0.0 goes forwards Z2
                    M569 P0.4 S1 ; physical drive 0.4 goes forwards extruder
                    M584 X0.3 Y0.2 Z0.1 Z0.0 E0.4 ; set drive mapping
                    M92 X80.00 Y128.00 Z400 Z400.00 E400.00 ; set steps per mm
                    M566 X900.00 Y900.00 Z60.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 Z180.00 E3900.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                    M906 X800 Y3000 Z3000 Z3000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X0 Y0 Z0 Z0 S1 ; set axis minima
                    M208 X609 Y609 Z762 Z762 S0 ; set axis maxima
                    M574 X1 S1 P"!^io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
                    M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
                    M574 Z1 S1 P"!^io3.in" ; configure active-high endstop for low end on Z via pin !^io3.in
                    M574 Z2 S1 P"!^io4.in" ; configure active-high endstop for low end on Z via pin !^io3.in
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M557 X15:600 Y15:600 S20 ; define mesh grid
                    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                    M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                    M143 H0 S110 ; set temperature limit for heater 0 to 110C
                    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                    M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
                    M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                    M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
                    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                    M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
                    M106 P3 S1 H-1 ; set fan 3 value. Thermostatic control is turned off
                    M563 P0 S"Himera" D0 H1 F0:2 ; define tool 0
                    ; Custom settings
                    M575 P1 B57600 S1
                      This isn't quite right. You'd need
                      M574 Z1 S1 P"!^io3.in+!^io4.in"
                      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
                      Instead of having 2 Z entries, you'd have M584 Z0.0:0.1 The driver numbers separated by a colon.
                      And for all of these commands you'd only need a single entry for Z since it's per axis, and not per driver. So remove the duplicate Z values. It's only for multiple extruders that you need to specify the values for each extruder.
                      The PanelDue is fairly limited in what it can display and how. You'd need to modify the firmware itself to do anything custom. https://github.com/Duet3D/PanelDueFirmware
                      What firmware version are you using on the Duet and on the PanelDue?
                      • supertb1undefined
                        supertb1
                        PanelDue-5.0i-7.0i.bin that I just installed from "https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24"
                        ok, thank you for helping me get that straight, next question, my homeall.g
                        ; homeall.g
                        ; called to home all axes
                        G91 ; relative positioning
                        G1 H1 X-614 Y-614 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X5 Y5 F6000 ; go back a few mm
                        G1 H1 X-614 Y-614 F360 ; move slowly to X and Y axis endstops once more (second pass)
                        G1 H1 Z-767 F360 ; move Z down stopping at the endstop
                        G90 ; absolute positioning
                        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                        ;G91 ; relative positioning
                        ;G90 ; absolute positioning
                        What changes need to be made to my home all and home Z files so that both Z motors move to the limit switches and stop, then zero, and then back up 5mm?
                          That's basically exactly what it's already doing.
                          Remove the semicolon ; from those three G code lines to back up 5mm after the endstop is hit.
                          • supertb1undefined
                            supertb1
                            Got it thanks so much.... can't wait to give this a try in the morning
                            • supertb1undefined
                              supertb1
                              ok, so I put the SD card in the slot on the Duet 3 today, the reset light on the board is still flashing and the PanelDue still sais Connecting, and now it will not let me move any of the axis through the PanelDue and when I type in the M552 command on the PanelDue it doesn't respond or return any information, I followed the 4 wire pin out instructions and put the PanelDue on I/O-0. I double checked the wiring, and the comment "M575 P1 B57600 S1" is present. Is there anything else I need to do to make this work?
                              • supertb1undefined
                                supertb1
                                I did some wiggle testing and found that the wiring from the duet 3 to the paneldue is flakey..... going to make a new cable and pay closer attention to the terminations... I always solder the wire ends before I crimp the terminal on the end... do you guys solder the terminal on to the wire as well?
                                  A good crimp should be on bare wire. If you solder first the crimp won't work properly.
                                  • supertb1undefined
                                    supertb1
                                    What gauge wire do you normally use with the crimps on the fans, sensors and steppers..?. I'm using nema 23 and 17 motors... I had been using 22 gauge wire
                                      22 is likely just fine for those things.
                                      • supertb1undefined
                                        supertb1
                                        it is likely that I do not have a good crimper for this task... what is the recommended crimper for this task?... my current problem is that when I crimp down on the terminal it cuts the wire end off and when I tine the wire ends before I crimp it solves this problem.
                                          There are many options. https://forum.duet3d.com/topic/9852/crimping-tool/
                                          • supertb1undefined
                                            supertb1
                                            many thanks... I'll get it ordered today... I'll leave you guys be for a while... headed to Cancun after christmas so it will be after that before I can get to this project... have a great holiday
