Duet 3 6HC micro SD socket damaged, need to send for repair
@supertb1 said in Duet 3 6HC micro SD socket damaged, need to send for repair:
so that I can can get things like the IP address and the limit switch inputs to display on the UI?
Which UI do you mean? On the PanelDue or the web interface?
You can create macros in the web interface and they would be accessible from the PanelDue or the web interface as well.
Most gcode commands can be sent without any parameters and it will echo back the current values.
Your PanelDue being stuck on connecting probably means that you're missing a command in config.g to enable it. You must have
M575 P1 B57600 S1
for the PanelDue to work.https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://duet3d.dozuki.com/Wiki/Gcode
Here are some example macros: https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3/macros
When I say user interface I guess I am trying to convey the PanelDue... I would like to have all of the sensors display current statuses , again thank you very much for the advice.
Could I have some one look at these G-codes in my config.g please
I am trying to set up for 2 Z motors, using Nema 23 motors and 3 pin limit switches. I am a bit of a noob so any advice would be helpfull. -
; generated by RepRapFirmware Configuration Tool v3.1.8 on Mon Nov 23 2020 22:57:12 GMT-0600 (Central Standard Time); General preferences
M550 P"Open Build Colosus" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.3 S1 ; physical drive 0.3 goes forwards X
M569 P0.2 S1 ; physical drive 0.2 goes forwards Y
M569 P0.1 S1 ; physical drive 0.1 goes forwards Z1
M569 P0.0 S1 ; physical drive 0.0 goes forwards Z2
M569 P0.4 S1 ; physical drive 0.4 goes forwards extruder
M584 X0.3 Y0.2 Z0.1 Z0.0 E0.4 ; set drive mapping
M92 X80.00 Y128.00 Z400 Z400.00 E400.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 Z180.00 E3900.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y3000 Z3000 Z3000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z0 Z0 S1 ; set axis minima
M208 X609 Y609 Z762 Z762 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!^io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
M574 Z1 S1 P"!^io3.in" ; configure active-high endstop for low end on Z via pin !^io3.in
M574 Z2 S1 P"!^io4.in" ; configure active-high endstop for low end on Z via pin !^io3.in; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:600 Y15:600 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
M106 P3 S1 H-1 ; set fan 3 value. Thermostatic control is turned off; Tools
M563 P0 S"Himera" D0 H1 F0:2 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M575 P1 B57600 S1; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
M574 Z2 S1 P"!^io4.in" ; configure active-high endstop for low end on Z via pin !^io3.inThis isn't quite right. You'd need
M574 Z1 S1 P"!^io3.in+!^io4.in"
Instead of having 2 Z entries, you'd have M584
Z0.0:0.1
The driver numbers separated by a colon.M92 X80.00 Y128.00 Z400 Z400.00 E400.00 ; set steps per mm
M208 X609 Y609 Z762 Z762 S0 ; set axis maximaAnd for all of these commands you'd only need a single entry for Z since it's per axis, and not per driver. So remove the duplicate Z values. It's only for multiple extruders that you need to specify the values for each extruder.
The PanelDue is fairly limited in what it can display and how. You'd need to modify the firmware itself to do anything custom. https://github.com/Duet3D/PanelDueFirmware
What firmware version are you using on the Duet and on the PanelDue?
PanelDue-5.0i-7.0i.bin that I just installed from "https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24"
ok, thank you for helping me get that straight, next question, my homeall.g
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-614 Y-614 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-614 Y-614 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-767 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioningWhat changes need to be made to my home all and home Z files so that both Z motors move to the limit switches and stop, then zero, and then back up 5mm?
That's basically exactly what it's already doing.
;G90 ; absolute positioningRemove the semicolon
from those three G code lines to back up 5mm after the endstop is hit. -
Got it thanks so much.... can't wait to give this a try in the morning
ok, so I put the SD card in the slot on the Duet 3 today, the reset light on the board is still flashing and the PanelDue still sais Connecting, and now it will not let me move any of the axis through the PanelDue and when I type in the M552 command on the PanelDue it doesn't respond or return any information, I followed the 4 wire pin out instructions and put the PanelDue on I/O-0. I double checked the wiring, and the comment "M575 P1 B57600 S1" is present. Is there anything else I need to do to make this work?
I did some wiggle testing and found that the wiring from the duet 3 to the paneldue is flakey..... going to make a new cable and pay closer attention to the terminations... I always solder the wire ends before I crimp the terminal on the end... do you guys solder the terminal on to the wire as well?
A good crimp should be on bare wire. If you solder first the crimp won't work properly.
What gauge wire do you normally use with the crimps on the fans, sensors and steppers..?. I'm using nema 23 and 17 motors... I had been using 22 gauge wire
22 is likely just fine for those things.
it is likely that I do not have a good crimper for this task... what is the recommended crimper for this task?... my current problem is that when I crimp down on the terminal it cuts the wire end off and when I tine the wire ends before I crimp it solves this problem.
There are many options. https://forum.duet3d.com/topic/9852/crimping-tool/
many thanks... I'll get it ordered today... I'll leave you guys be for a while... headed to Cancun after christmas so it will be after that before I can get to this project... have a great holiday
