    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.4k
    • stuartofmtundefined
      stuartofmt @JohnOCFII
      @JohnOCFII
      Good to hear. When you say add 2 seconds - do you mean continue recording for 2 second after Duet reports that it is no longer printing ?
        @JohnOCFII
        Maybe a small change like this at the end ?
                elif (printerState == 2):
                    onePhoto()
                    time.sleep(2)
                    onePhoto()
                    postProcess()
          @JohnOCFII
          Seeing I'm on a (UNTESTED) role. This may be better than the crude suggestion above. Note that it requires ffmpeg from Nov 2018 or newer.
          I'll try it later today as I have a print to get done.
          def postProcess():
              print()
              print("Now making {0:d} frames into a video at 10 frames per second.".format(int(np.around(frame))))
              if (250 < frame): print("This can take a while...")
          #    fn = basedir+'DuetLapse'+time.strftime('%m%d%y%H%M',time.localtime())+'.mp4'
              fn = basedir+'DuetLapse'+time.strftime('%a-%H:%M',time.localtime())+'.mp4'
              if (vidparms == ''):
                  cmd  = 'ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 tpad=stop_mode=clone:stop_duration=2 '+fn
          #        cmd  = 'ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 '+fn
              else:
                  cmd  = 'ffmpeg '+vidparms+' -i /tmp/DuetLapse/IMG%08d.jpeg tpad=stop_mode=clone:stop_duration=2 '+fn
          #        cmd  = 'ffmpeg '+vidparms+' -i /tmp/DuetLapse/IMG%08d.jpeg '+fn
              subprocess.call(cmd, shell=True)
              print('Video processing complete.')
              print('Video file is in '+basedir+' directory, named '+fn)
              exit()
          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          • JohnOCFIIundefined
            JohnOCFII @stuartofmt
            @stuartofmt Yes -- something like that. Basically hold the last image for 2 seconds.
            Here's how OctoPrint refers to it:
              stuartofmt
              Seems like the tpad filter is missing from my version (4.1.6) of ffmpeg Debian Buster on Pi.
              Also the syntax above may (or not) work ....
              I may have to compile ffmpeg from the latest source - will let you know.
                @stuartofmt said in DuetLapse available for Alpha testing:
                I seem to have the same version of ffmpeg:
                ffmpeg version 4.1.6-1~deb10u1+rpt1 Copyright (c) 2000-2020 the FFmpeg developers
                I should troll through the OctoPrint/OctoPi code to see what they do.
                • oozeBotundefined
                  oozeBot
                  In case it went overlooked, I just wanted to toss out there that I came up with a solution for timelapse video when using a Duet 3 with attached Raspberry Pi..
                  https://forum.duet3d.com/topic/19225/timelapse-video-through-execonmcode
                  stuartofmtundefined 1 Reply Last reply Reply Quote 0
                    stuartofmt @oozeBot
                    @oozeBot
                    Thanks - a nice piece of work. I looked at it at one time but did not want to fiddle with generating the additional slicer code (likely an irrational reaction).
                    In my case I could replace the wget with ffmpeg for the stream output from the app I am using and also the modified aggregation ffmpeg.
                    I may end up back at your script - but for now I am wrestling with recompiling ffmpeg to get some additional filters that are not present in the somewhat old Pi version.
                    oozeBotundefined 1 Reply Last reply Reply Quote 0
                    • oozeBotundefined
                      oozeBot @stuartofmt
                      @stuartofmt I get it, but maybe there is something there that could be built upon. It would also be possible to put the trigger in daemon.g but I wanted to control the trigger within the gCode at precisely the same point, etc..
                        stuartofmt @oozeBot
                        @oozeBot
                        Just so you know - DuetLapse is working fine and has some nice features. I'm just embellishing around the edges.
                        Being unfamiliar with Python - some of it is trial and error. Also some of it (e.g. ffmpeg on Pi being quite old) would be the same in either approach.
                        I've written quite a few bash scripts in the past and it would be a bit of a slog to achieve the same flexibility as DuetLapse with bash - although not impossible by any means.
                        As of this afternoon - I have another embellishment done (required newer ffmpeg) and and will update my git repository shortly.
                          stuartofmt
                          @JohnOCFII
                          I'm pretty well there - doing some final testing now. I'll post the new DuetLapse.py later today / tomorrow. It has additional parameters to control the output directory and the extra time at the end. The defaults are the same as before.
                          I'm PRETTY sure that the standard Pi ffmpeg does not have tpad - but you can test with the following command to see (required a different syntax than I originally tried) .... I updated ffmpeg before I found this working syntax ....
                          ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -c:v libx264 -vf tpad=stop_mode=clone:stop_duration=2,fps=10 ./out1.mp4
                          Here are the steps I went through to build a more up-to-date ffmpeg (well - the straight line version that avoids the various dead ends and failures to compile the optional packages). They were taken from here but shortened to omit the optional packages in the post and using a build that omits calling those packages.
                          https://pimylifeup.com/compiling-ffmpeg-raspberry-pi/
                          1. Remove existing ffmpeg
                          sudo apt remove ffmpeg
                          1. Make sure OS is up to date
                          sudo apt update
                          sudo apt upgrade
                          1. Install dependencies
                          sudo apt -y install autoconf automake build-essential cmake doxygen git graphviz imagemagick libasound2-dev libass-dev libavcodec-dev libavdevice-dev libavfilter-dev libavformat-dev libavutil-dev libfreetype6-dev libgmp-dev libmp3lame-dev libopencore-amrnb-dev libopencore-amrwb-dev libopus-dev librtmp-dev libsdl2-dev libsdl2-image-dev libsdl2-mixer-dev libsdl2-net-dev libsdl2-ttf-dev libsnappy-dev libsoxr-dev libssh-dev libssl-dev libtool libv4l-dev libva-dev libvdpau-dev libvo-amrwbenc-dev libvorbis-dev libwebp-dev libx264-dev libx265-dev libxcb-shape0-dev libxcb-shm0-dev libxcb-xfixes0-dev libxcb1-dev libxml2-dev lzma-dev meson nasm pkg-config python3-dev python3-pip texinfo wget yasm zlib1g-dev libdrm-dev
                          1. Build ffmpeg (takes a while)
                          git clone --depth 1 https://github.com/FFmpeg/FFmpeg.git ~/FFmpeg \
                            && cd ~/FFmpeg \
                            && ./configure \
                              --extra-cflags="-I/usr/local/include" \
                              --extra-ldflags="-L/usr/local/lib" \
                              --extra-libs="-lpthread -lm -latomic" \
                              --arch=armel \
                              --enable-gmp \
                              --enable-gpl \
                              --enable-libass \
                              --enable-libdrm \
                              --enable-libfreetype \
                              --enable-libmp3lame \
                              --enable-libopencore-amrnb \
                              --enable-libopencore-amrwb \
                              --enable-libopus \
                              --enable-librtmp \
                              --enable-libsnappy \
                              --enable-libsoxr \
                              --enable-libssh \
                              --enable-libvorbis \
                              --enable-libwebp \
                              --enable-libx264 \
                              --enable-libx265 \
                              --enable-libxml2 \
                              --enable-mmal \
                              --enable-nonfree \
                              --enable-omx \
                              --enable-omx-rpi \
                              --enable-version3 \
                              --target-os=linux \
                              --enable-pthreads \
                              --enable-openssl \
                              --enable-hardcoded-tables \
                            && make -j$(nproc) \
                            && sudo make install
                          1. Check the ffmpeg version
                          pi@srsenderpi:~ $ ffmpeg -version
                          ffmpeg version git-2020-12-22-a7f9b3b Copyright (c) 2000-2020 the FFmpeg developers
                          built with gcc 8 (Raspbian 8.3.0-6+rpi1)
                          configuration: --extra-cflags=-I/usr/local/include --extra-ldflags=-L/usr/local/lib --extra-libs='-lpthread -lm -latomic' --arch=armel --enable-gmp --enable-gpl --enable-libass --enable-libdrm --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libssh --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-mmal --enable-nonfree --enable-omx --enable-omx-rpi --enable-version3 --target-os=linux --enable-pthreads --enable-openssl --enable-hardcoded-tables
                          libavutil      56. 62.100 / 56. 62.100
                          libavcodec     58.115.102 / 58.115.102
                          libavformat    58. 65.100 / 58. 65.100
                          libavdevice    58. 11.103 / 58. 11.103
                          libavfilter     7. 94.100 /  7. 94.100
                          libswscale      5.  8.100 /  5.  8.100
                          libswresample   3.  8.100 /  3.  8.100
                          libpostproc    55.  8.100 / 55.  8.100
                          ffmpeg - filters shows tpad being available.
                            @JohnOCFII
                            I'll try this tomorrow (US Central time - GMT-6).
                              @JohnOCFII
                              Updated here:
                              https://github.com/stuartofmt/DuetLapse
                                @JohnOCFII
                                Updated here:
                                Greetings!
                                I was hoping that simply replacing ffmpeg and the new DuetLapse.py would "just work," but sadly, not the case.
                                I confirmed that my previous ffmpeg didn't have support for the pad filter, as you suggested.
                                I rebuilt ffmpeg according to your instructions. That all went well.
                                I then tried to execute the DuetLapse script but you addition of -psutil- wasn't working, so I Googled how to build that, and did so.
                                I then went to run DuetLapse, but received the message:
                                Process is already running...
                                Probably because I have DuetLapse starting from -systemd-
                                I'll have to see what else is different.
                                John
                                  @JohnOCFII
                                  If you are using my DuetLapse.py then it will prevent starting twice - so you need to make sure it's stopped before starting it again 🙂
                                  kill -s <pid> if you are running in background else CTL+C works.
                                    @JohnOCFII
                                    Heh - yeah, I might switch back to my DuetLapse, but take your ffmpeg command line. I have mine set to run and restart continuously, that way, I'll get a timelapse created every time a print starts.
                                    John
                                      @JohnOCFII
                                      If you are using systemd and it’s set up correctly then you should be fine with my version. All my code does on startup is look to see if there is an instance already running and if so - not create an additional instance (which would case “confusion”). Similarly systemd should not try to start a new instance if there is one already running (if you have it set up that way).
                                      Bottom line, they should be compatible with each other.
                                        @JohnOCFII
                                        Yes, you are correct -- but I also have a little test script that attempts to launch an additional copy of DuetLapse that I use when testing new features. And it was attempting to launch THAT that caused my issues. 🙂
                                        So, yes, I stuck with your version but did comment out the process related bits for testing.
                                          stuartofmt
                                          I’ll add in a switch so you can control with / without the check. May be useful ...
                                            Lovely idea!
