Mini 5 no heaters
This post is deleted! -
what is wrong with his heater code ?
i have very similar on my corexy and it works fine, im genuinely interested in seeing what you think is wrong with it.
if he has the heater wired to the tool-board in the following manner
heater cartridge = out0
thermistor = temp1then what should the g code be ?
he wrote he connected it to out1 but wrote out0 in the code
@Veti said in Mini 5 no heaters:
we will need a picture of the tool-board to check that.
@JayJay please post a picture of your tool-board wiring
Thank you all for the input.
@Veti thanks for the advice on moving the heater wires, i used out2 because i have an SSR and thought it would be ok to use, i moved the wires to out0 and changed the config, and now the bed heater works.
I also updated the toolboard firmware to Duet TOOL1LC firmware version 3.2-RC2 (2020-12-24)
And now since doing that the temp reading has dissappeared and shows n/a where as before it did show the correct temp, and i can now click on the hot end button and activate it but as there is no temp reading i get a fault, so i just need to work on that now.
@CaLviNx
my originalpost about the toolboard being on out1 is a typo it is wired into out0 same as the config.
can you post the M122 of both the mini and the toolboard. maybe there is a can communication problem.
i also tried moving the thermistor to temp0 and that shows as n/a also
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta3.2+1 running on Duet 3 Mini5plus WiFi (standalone mode) Used output buffers: 3 of 40 (11 max) === RTOS === Static ram: 97472 Dynamic ram: 132764 of which 368 recycled Never used RAM 30516, free system stack 176 words Tasks: NETWORK(ready,168) HEAT(blocked,195) CanReceiv(blocked,875) CanSender(blocked,371) CanClock(blocked,370) TMC(blocked,56) MAIN(running,448) IDLE(ready,20) AIN(blocked,258) Owned mutexes: === Platform === Last reset 00:03:29 ago, cause: software Last software reset at 2020-12-29 14:51, reason: User, GCodes spinning, available RAM 30516, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0x00 Supply voltage: min 0.0, current 23.6, max 23.6, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 39, reads 29883, writes 9, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 39, reads 29883, writes 9, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 39, reads 29883, writes 9, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 39, reads 29883, writes 9, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 39, reads 29883, writes 9, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2020-12-29 14:55:14 Slowest loop: 10.22ms; fastest: 0.12ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.3ms, write time 4.7ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 26.88ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.25beta0 WiFi MAC address f4:cf:a2:6f:bd:af WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 26680 WiFi IP address 192.168.0.115 WiFi signal strength -48dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 0, send timeouts 0, longest wait 2ms for type 6049, free CAN buffers 15 M122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2-RC2 (2020-12-24) Bootloader ID: not available Never used RAM 4176, free system stack 96 words HEAT 90 CanAsync 89 CanRecv 83 TMC 54 MAIN 324 AIN 64 Last reset 00:05:42 ago, cause: software Last software reset data not available Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 51, reads 39933, writes 10, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.0V MCU temperature: min 32.2C, current 32.6C, max 32.6C Ticks since heat task active 61, ADC conversions started 342054, completed 342053, timed out 0 Last sensors broadcast 0x00000000 found 0 64 ticks ago, loop time 0 CAN messages queued 2765, send timeouts 0, received 3098, lost 0, free buffers 36 -
@JayJay said in Mini 5 no heaters:
you did not do the update to 3.2-RC2
after the update power the entire system down and up again
hmmm i dont know why it is saying that as i definately downloaded the rc2 candidate from github
i uploaded it to the board and it asked me if i wantted to update which i did.
i think the correct file is : Duet3Firmware_Mini5plus.uf2
and : Duet3_SDiap32_Mini5plus.bin -
rename the old Duet3_SDiap_Mini5plus.bin to old
and copy another version of Duet3_SDiap32_Mini5plus.bin and remove the 32 and try the firmware update again. -
that cured all thank you.
but i want to know why the bed didnt work on out2 ? as with an SSR it should have been fine
maybe a bad crimp job?
nah my job is an auto electrician the crimps were fine i checked continuity with a meter too.
Yes it should have worked, provided that the fuse for the heaters/motors/fans is intact (the bed heater uses a separate fuse).
- Did the red LED next to OUT2 light when you tried to turn on the bed heater?
- Did you try running M98 P"config.g" to check for errors in the config,g file?
@dc42 said in Mini 5 no heaters:
The fuses are all intact.
I cant remember if the LED turned on or not, since i moved it to out0 and it worked i left it alone.
M98 reports
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled but i am now encountering an issue with getting the probe to be recognised during G32
