    who can i mail this 6hc to to get it fixed
    Firmware installation
    firmware
    590
      A Former User @bam
      @bam said in who can i mail this 6hc to to get it fixed:
      the mb has been reflashed with bossa.
      given you have been able to flash it, the same computer and cable would be likely to still work (but I'd still try a different computer/cable after erasing)
      if the paneldue isn't connecting in standalone mode (with it enabled in config.g) to send M997 as an attempt at reflashing the board with firmware from sd card you've got nothing to loose by trying to erase the board and seeing if that allows you to flash with bossa again.
      ref https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_To_update_via_USB_using_a_Windows_host for instructions on using the erase jumper if you haven't tried that already.
      the bootloader in the cpu is in read only memory so you can't really break the bootloader (flashing diag led indicate running firmware normally, so it will not show up in bossa)
        If you've flashed it once already then try and connect to it via YAT terminal software to see if it will respond to commands. If so, then try getting it running in standalone mode before adding the Pi into the mix.
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
        You'll need a fresh SD card that you can put the folder structure on and a config.g in the /sys folder. The DWC files in the /www folder etc. Put that in the Duet and try and boot it. It should get an IP address from your router you can connect to.
        • bamundefined
          bam
          getting YAT online now
          m122 b1
          Error: M122: Response timeout: CAN addr 1, req type 6024, RID=0<LF>Error: M122: Response timeout: CAN addr 1, req type 6024, RID=1<LF>Error: M122: Response timeout: CAN addr 1, req type 6024, RID=2<LF>ok<LF>
          m115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-12-24<LF>ok<LF>
            That's a good sign. Now if you get an SD card in the Duet you should be able to get to the web interface.
            • bamundefined
              bam
              So ive gotten the mainboard on 3.3.1, the panel due on 1.24 and the pi now talks to the mainboard. {paneldue just says connecting}. may have to send a paneldue interface code or something, not sure yet. right now im trying to figure out how to get the 3hc on the right firmware
                PanelDue needs M575 P1 B57600 S1 in config.g
                • bamundefined
                  bam
                  awesome! last thing and then i can start wiring, how do i find out what the address is for the 3hc?
                  • bamundefined
                    bam
                    or what firmware is on it? doesnt seem to have an sd card slot or micro usb. im using regular old phone cord to connect it to the 6hc
                      https://duet3d.dozuki.com/Wiki/CAN_connection
                      Once you set an address you can use M122 B# to get info for it
                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M122_Diagnose
                      bamundefined 1 Reply Last reply Reply Quote 0
                      • bamundefined
                        bam
                        this is what i got when i ran m997 b1
                        12/31/2020, 10:26:56 PM m997 b1
                        Error: M997: Response timeout: CAN addr 1, req type 6024, RID=0
                        12/31/2020, 10:26:56 PM Connection to Duet established
                        12/31/2020, 10:26:55 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                        • bamundefined
                          bam @Phaedrux
                          This post is deleted!
