    Need help with mesh bed levelling
    2.8k
    • Vetiundefined
      Veti @medicusdkfz
      @medicusdkfz said in Need help with mesh bed levelling:
      After I do a G29 S1, I have to do a homing with G30 Z-9999?
      no before you do a G29 S1 you need to do a G30
      • medicusdkfzundefined
        medicusdkfz
        Without any parameter?
        • fcwiltundefined
          fcwilt @medicusdkfz
          G30 by itself is used to set the Z=0 datum.
          You first need to move to your XY reference point - I use the center of the bed.
          Setting the Z=0 datum needs to be done when creating the height map and when loading the height map.
            medicusdkfz
            I see! I've tried it and it works... I'm very happy! Thank you for your help!!!!!
            Pierre
            • Vetiundefined
              Veti @medicusdkfz
              what firmware version are you running? because if you did not do that, there should have been a warning in the console
                medicusdkfz
                This post is deleted!
                  medicusdkfz
                  A happy new year to you all!
                  Sorry, I still have trouble. In a first attempt it looked good. But yesterday I did a print over the whole bed with a lot of trouble. After homing and qgl, I go to the middle of the bed and do a G30. Then I do a very fine mesh bed levelling with 420 points. Before printing I do again a G30 and activate the mesh with G29 S1. But then I have a bad first layer. When I activate my mesh without printing after a G30 in the middle of the bed, I have inconsistent Z-heights in the paper test. I guess, that I should have at every point inside the mesh coordinates the same heights under the nozzle. But it isn't! Any suggestions?
                  Thank you very much,
                  Pierre
                  • fcwiltundefined
                    fcwilt @medicusdkfz
                    @medicusdkfz
                    After doing a G30 at the center of the bed have you verified that the Z position is correct?
                    If you move to Z=0 is the tip of the nozzle touching (or almost touching) the bed?
                      Can you show us your gcode commands being executed?
                      What is in your slicer start gcode and any of the files called from there. homeall.g, bed.g, etc
                        medicusdkfz
                        I solved my problem... First layer with 0.2mm height...
                          medicusdkfz
                          Based on the configuration of Fulg (Voron Discord) - many thanks to you...
                          config.g:
                          M111 S0                 							; Debugging off
                          G21                     							; Work in millimetres
                          G90                     							; Send absolute coordinates...
                          M83                     							; ...but relative extruder moves
                          M555 P2                 							; Set firmware compatibility to look like Marlin
                          M575 P1 B57600 S1       							; Comms parameters for PanelDue
                          M564 S1 H1              							; Forbid axis movements when not homed
                          M552 P0.0.0.0 S1                           			; enable network and acquire dynamic address via DHCP
                          M554 P0.0.0.0										; gateway
                          M553 P255.255.255.0									; subnet mask
                          M586 P0 S1                                          ; enable HTTP
                          M586 P1 S1                                         	; enable FTP (for remote backups)
                          M586 P2 S0                                         	; disable Telnet
                          ; General setup
                          M669 K1                 							; Select CoreXY mode (2.03 and up)
                          M550 PVoron 2.4 350mm^3                           	; set printer name
                          ; Drives for XY
                          M569 P0.4 S1                                       	; A motor (X)
                          M569 P0.5 S0                                       	; B motor (Y)
                          ; Drives for Z
                          M569 P0.0 S1                                       	; Front left
                          M569 P0.1 S0                                       	; Back left
                          M569 P0.2 S1                                       	; Back right
                          M569 P0.3 S0                                       	; Front right
                          ; Drive for extruder
                          M569 P1.0 S1                                       	; physical drive 1.0 goes forwards
                          M572 D0 S0.025										; pressure advance
                          ; Motor mapping and steps per mm
                          M584 X0.4 Y0.5 Z0.0:0.1:0.2:0.3 E1.0				; set drive mapping
                          M350 X16 Y16 Z16 E16 I1         					; Use 1/16 microstepping with interpolation everywhere
                          M92 X160 Y160 Z800              					; Set XYZ steps per mm (0.9deg motors)
                          M92 E410                        					; Set Extruder steps per mm
                          ; Drive currents
                          M906 X1200 Y1200 Z1200 E600     					; XYZ and E current
                          M906 I30                        					; Idle current percentage
                          M84 S120                        					; Idle timeout
                          ; Accelerations and speed
                          M98 P"/macros/print_scripts/speed_printing.g"
                          ; Axis travel limits
                          M208 X0 Y1 Z-4 S1                                	; set axis minima
                          M208 X346 Y355 Z320 S0                             	; set axis maxima
                          M574 X2 S1 P"!io1.in"                               ; X Hall effect endstop
                          M574 Y2 S1 P"!io2.in"                               ; Y Hall effect endstop
                          M574 Z0 P"nil"										; no Z endstop
                          M558 K0 P8 C"^io4.in" I1 H3 F200 T18000 A5 S0.01 B0 R0.2 	; set Z probe type to switch and the dive height + speeds
                          G31 P1000 X0 Y23.5 Z2.000                            	; set Z probe trigger value, inductive probe offset and trigger height (Papiertest, G92 Z0 setzen und anschliessend G30 S-1/G1 Z5 mehrfach wiederholen -> Höhe = Offset
                          M558 K1 P8 C"io3.in" T18000 F60 H2 A10 S0.005 R0.2
                          G31 K1 P500 X0 Y0 Z-0.489            					; Z switch offset (if positive, greater value = lower nozzle. if negative, more negative = higher nozzle)
                          M671 X-62:-62:407.5:407.5 Y-1:429:429:-1 S20        	; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
                          M557 X10:340 Y30:320 S33:29                         	; Anfahrtpunkte für Sonde!!! define mesh grid (for G29) - überschreibt Grideinstellungen in DOW nach Neustart
                          ; Hotbed (dual thermistor setup)
                          M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenovo"    				; configure sensor 0 as thermistor on pin temp0 (heater sensor)
                          M308 S2 P"temp2" Y"thermistor" T100000 B3950 A"Heizbett direkt"      	; configure sensor 2 as thermistor on pin temp2
                          M950 H0 C"out0" T2 Q10                                					; Heater --> SSD-Steuerung
                          M307 H0 A261.9 C549.2 D0.7 V24.0 B0			   							; Heater 0 model: gain 261.9, time constant 549.2, dead time 0.7, max PWM 1.00, calibration voltage 24.0, mode PID
                          M140 P0 H0                                            						; Map heated bed to heater 0 - Keenovo 220V, 750W
                          M143 H0 P1 T0 A2 S125 C0                                    ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 115°C. Use Heater monitor 1 for it
                          M143 H0 P2 T0 A1 S130 C0                                    ; Shut off (A1) bed heater (H0) if pad sensor (T0) exceeds 125°C. Use Heater monitor 2 for it
                          M143 H0 S120                                                ; Set bed heater max temperature to 120°C, use implict monitor 0 which is implicitly configured for heater fault
                          M307 H0 B1 S0.9                                             ; Enable Bang Bang mode and set PWM to 60% to avoid warping
                          ; Hotend
                          M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.196220e-7 A"Mosquito"      	; Thermistor R-Wert eicht die Temp R3950
                          M950 H1 C"out1" T1                                 							; Heater
                          M307 H1 A593.7 C180.4 D7.6 V24.0 B0				   							; Heater 1 model: gain 593.7, time constant 180.4, dead time 7.6, max PWM 1.00, calibration voltage 24.0, mode PID
                          M143 H1 S350																; Sets temperature limit for extruder - Mosquito
                          ; DHT22 sensor
                          ;M308 S10 P"0.spi.cs0" Y"dht22"       A"Chamber Temp"    ; Temperature (connected to cs0 port on the temp daughterboard slot
                          ;M308 S11 P"S10.1"     Y"dhthumidity" A"Chamber Hum[%]"  ; Humidity
                          ; MCU sensors
                          M308 S3 Y"mcu-temp" A"MCU"
                          M308 S4 Y"drivers" A"Duet Drivers"
                          ; Main fans
                          M950 F0 C"1.out6" Q500                             	; Part cooling fan
                          M106 P0 S0 B0.1 H-1                                	; Default off; booststart for 0.1s (B0.1); thermostatic control off
                          M950 F1 C"out7" Q500                           	   	; Hotend cooling fan
                          M106 P1 S255 H1 T50                                	; Default on; thermistatic control on above 50C
                          ; Aux fans (option to control daughter board fans based on main board temp sensor coming in RRF3.3, for now has to be manual)
                          M950 F2 C"1.out7" Q500                              ; Electronics compartment fan 1
                          M106 P2 S1.0 H-1                                    ; Default on; thermostatic control off
                          M950 F3 C"1.out8" Q500                              ; Electronics compartment fan 2
                          M106 P3 S1.0 H-1									; Default on; thermostatic control off
                          M950 F6 C"out8" Q500								; Noctua exhaust filter fan
                          M106 P6 S0 H-1										; Default off
                          ; LED-Stripes
                          ;M950 F5 C"out9" Q500								; LED-Streifen rechts --> derzeit nicht installiert
                          ;M106 P5 S1.0 H-1                                   ; Default on; thermostatic control off
                          ; Misc
                          M912 P0 S-4                         				; MCU temperature calibration (yours will be different)
                          M572 D0 S0.01                       				; Pressure Advance
                          M592 D0 A0.015 B0.0012 L0.2         				; Non-linear extrusion
                          M376 H10                            				; Fade mesh out compensation over 10mm Z
                          M563 P0 D0 H1 F0                    				; Define tool 0 using fan 0 for M106
                          G10 P0 X0 Y0 Z0                     				; Set tool 0 axis offsets
                          G10 P0 R0 S0                        				; Set initial tool 0 active and standby temperatures to 0C
                          ; DAA tuning (you will need to change this for your slicer)
                          ;M593 F26.6                          				; Cura 4.5 stock profile @ 40mm/s outer printing speed
                          M593 F42.5                          				; PrusaSlicer @ 40mm/s outer perimeter
                          M80                                 				; turn on PSU & mains voltage
                          M501                                				; load config-override.g
                          T0                                  				; select tool 0
                          ; workaround for bug in 3.2beta3, M143 needs to be done after all M950, M307, M140 and M141. https://forum.duet3d.com/topic/19031/m143-issue/25?_=1605986986974
                          M143 H0 S115
                          M143 H1 S350
                          homeall.g:
                          ; homeall.g
                          ; called to home all axes
                          ; Relative positioning
                          G91
                          ; Lower currents, speed & accel
                          M98 P"/macros/print_scripts/xy_current_low.g"
                          ;M98 P"/macros/print_scripts/z_current_low.g"
                          M98 P"/macros/print_scripts/speed_probing.g"
                          ; Lift Z relative to current position if needed
                          if !move.axes[2].homed
                            G1 Z10 F9000 H1
                          elif move.axes[2].userPosition < 10
                            G1 Z10 F9000
                          ; Coarse home X or Y
                          G1 X600 Y600 F2400 H1
                          ; Coarse home X
                          G1 X600 H1
                          ; Coarse home Y
                          G1 Y600 H1
                          ; Move away from the endstops
                          G1 X-5 Y-5 F9000
                          ; Fine home X
                          G1 X600 F360 H1
                          ; Fine home Y
                          G1 Y600 H1
                          ; Absolute positioning
                          G90
                          ; Home Z microswitch
                          M98 P"/macros/print_scripts/goto_z_switch.g"
                          G30 K1 Z-9999
                          if move.axes[2].userPosition < 5
                          	G1 Z5
                          ; Restore high currents, speed & accel
                          M98 P"/macros/print_scripts/xy_current_high.g"
                          ;M98 P"/macros/print_scripts/z_current_high.g"
                          mesh.g:
                          ; give one last chance to cancel...
                          M291 P"This will replace the existing bed mesh. Are you sure?" R"Bed Mesh" S3
                          ; Level the gantry so we can park the carriage in the middle of the bed
                          G32
                          M98 P"/macros/print_scripts/goto_bed_center.g"
                          ; Heat the bed to 100C
                          M291 P"Heating up the bed..." R"Probing New Bed Mesh" T5
                          M190 S100
                          ; Set the hotend to 250C
                          M291 P"Heating up the hotend..." R"Bed Mesh" T5
                          G10 P0 S250
                          M116
                          ; Level the gantry again while everything is hot
                          M291 P"QGL while everything is hot..." R"Bed Mesh" T5
                          G32
                          ; ignore current heightmap
                          M561
                          ; Establish final Z ref
                          M291 P"Final Z ref..." R"Bed Mesh" T5
                          M98 P"/macros/print_scripts/do_nozzle_wipe.g"
                          G28 Z
                          ; Get the reference Z offset
                          M291 P"Get reference Z offset..." R"Bed Mesh" T5
                          	G1 Z5
                          G30 K0 S-1
                          G1 Z5
                          G30 K0 S-1
                          G1 Z5
                          G30 K0 S-1
                          G1 Z5
                          G30 K0 S-3
                          G1 Z5
                          ; Probe a new bed mesh!
                          M291 P"Probing now!" R"Bed Mesh" T5
                          M557 X10:340 Y30:320 S41.25:36.25; 81 Anfahrtpunkte für Sonde!!! define mesh grid (for G29) - überschreibt Grideinstellungen in DOW nach Neustart
                          G29 S0
                          ; Done, move to center and turn off heat
                          	G1 Z5
                          G10 P0 S0
                          M140 S0
                          M291 P"Done!" R"Bed Mesh" T5
                          bed_probe_points.g:
                          ;###### Pierre ######
                          ;G30 K0 P0 X10 Y26 Z-99999; probe near front left belt
                          ;G30 K0 P1 X10 Y315 Z-99999; probe near back left belt
                          ;G30 K0 P2 X340 Y315 Z-99999; probe near back right belt
                          ;G30 K0 P3 X340 Y26 Z-99999 S4; probe near front right belt
                          ;####### fulg #######
                          G30 K0 P0 X340 Y315 Z-99999
                          G30 K0 P1 X340 Y26 Z-99999
                          G30 K0 P2 X10 Y26 Z-99999
                          G30 K0 P3 X10 Y315 Z-99999 S4
                          bed.g:
                          ; bed.g
                          ; Called to align the gantry to the bed plane via G32
                          ; Clear any bed transform
                          M561
                          ; Turn off noisy Extruder motor
                          M84 E
                          ; Home all axes
                          G28
                          ; Probe the bed at 4 points, x3 for more precision
                          M558 K0 H5 F240   ; reduce depth range, probe slower for better repeatability
                          M98 P"/sys/bed_probe_points.g"
                          M558 K0 H4 F240   ; reduce depth range, probe slower for better repeatability
                          while true
                            if iterations = 5
                              abort "Too many auto calibration attempts"
                            	M558 K0 H1 F60    ; reduce depth range, probe slower for better repeatability
                            if result != 0
                              continue
                            if move.calibration.initial.deviation <= 0.005
                              break
                          ; If there were too many errors or the deviation is too high - abort and notify user
                            echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
                          echo "Auto calibration successful, deviation", move.calibration.initial.deviation ^ "mm"
                          	G1 Z5
                          G28 Z
                            medicusdkfz
                            Is it possible to define the number of probing attempts with the inductive probe while mesh bed leveling or a G30 at the probing point to increase the accuracy? Sometimes the first value is bad. But 3 or 4 are better...
                            Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                            • Vetiundefined
                              Veti @medicusdkfz
                              yes
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                              the A parameter.
                              but you already have it at 5
                              you could also try reducing the F parameter
                              • fcwiltundefined
                                fcwilt @medicusdkfz
                                You can force the averaging of a fixed number of readings by setting the M558 S parameter to -1 and setting the A parameter to the desired number of readings - see the M558 command docs.
                                  medicusdkfz
                                    medicusdkfz
                                    @Veti When do I need a G30 and when a G30 S-2 with mesh bed levelling? My first probe is a Z microswitch at the Voron 2.4. This is my reference also for temperature issues with the inductive probe. After homing and levelling the quad gantry, I want to do my mesh. At the process of creating a mesh I have to do what, before I perform a G29 S0?
                                    At the process of using an existing mesh I have to do what, before I perform a G29 S0?
                                    Today I had the warning again with the z datum...
                                    • Vetiundefined
                                      Veti @medicusdkfz
                                      G30 S-2
                                      you only need that if you are calibrating your probe initially
                                      G29 S0 is the same as G29
                                      you load an existing mesh with G29 S1
                                      you need to run a G30 (normally part of the homing) before executing G29 S1
                                        Phaedrux Moderator @Veti
                                        @Veti said in Need help with mesh bed levelling:
                                        G30 S-2
                                        That's G30 S-1
                                        @medicusdkfz I don't think you'd usually ever need G30 S-2
                                        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G30_Single_Z_Probe
                                        G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
                                        G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate, just report the machine height at which the probe was triggered.
                                        G30 S-2 ; Probe the bed at the current XY position. When the probe is triggered, adjust the Z offset of the current tool to make the current position Z=0.
                                        G30 S-3 ; Probe the bed and set the Z probe trigger height to the height it stopped at (supported in RRF 2.03 and later)
