    How to: G1 F<expression>
    Gcode meta commands
    676
    • fcwiltundefined
      fcwilt
      The documentation says this:
      iterations int The number of completed iterations of the innermost loop
      So how are we to interpret that when used it in nested whiles?
      Did you try removing the inner while to see if it made a difference?
      • OwenDundefined
        OwenD @schpongo
        @schpongo
        What is "not working"?
        I.e what was your intent vs what is happening?
        The way you've written it, it would (I think) complete five loops of the second level for each of the first.
        If you're intent is to only do the second half on the first five iterations of the first, then use an IF statement.
        • schpongoundefined
          schpongo
          Sorry for being no specific enough. Line 4 is not working. Thus the feedrate always stays at F6000 from the command in line 3. I've tried echoing the calculation inn line 4 and it works. But the combination with the G1 command does not seem to work.
          whosrdaddyundefined 1 Reply Last reply Reply Quote 0
          • whosrdaddyundefined
            whosrdaddy @schpongo
            This post is deleted!
              dc42 administrators @schpongo
              @schpongo said in How to: G1 F<expression>:
              Hey, I have a quick question.
              I'm trying to write a loop were in each loop iteration the set feedrate increases.
              My current approach is the following, but this isn't working. Does anyone have any pointers?
              while iterations < 10
              	G28 U
              	G1 U180 F6000
              	G1 F{6000+iterations*2000}
              	while iterations <5
              		G1 U56
              		G1 U304
              I've tried replacing the {} with () or [] but did not have any success.
              I've just tried that on my delta, with a few changes to suit the geometry:
              	G28
              	G1 X0 Y0 Z50 F6000
              	while iterations <5
              		G1 X-150
              		G1 X150
              It works for me as expected. For each iteration of the outer loop, the speed of the moves in the inner loop increases. I'm using RRF 3.2beta1.
              • schpongoundefined
                schpongo
                Hey, sorry for the late reply.
                I tried your code again and changed the axes but it still does not work.
                G28V
                	G1 X0 Y0 Z50 F6000
                	while iterations <5
                		G1 V-150
                		G1 V150
                The result in the console is:
                Failed to execute G1 in test: [ArgumentException] Cannot convert F parameter to float (value {6000+0*2000})
                The problem is no longer relevant to me but there may still be a bug here which needs fixing.
                • garethkyundefined
                  garethky
                  I just ran into this with a simple expression like:
                  G1 E1 F{600.0 + 1.0}
                  which gives the error:
                  Error: Operation failed (Reason: ArgumentException in SimpleCode: Cannot convert F parameter to float (value {600.0 + 1.0}))
                  I'm still on 3.1.1 so maybe this is fixed in 3.2+ (just a wild guess that @dc42 is running the latest firmware on that Delta)
                    dc42 administrators @garethky
                    @garethky said in How to: G1 F<expression>:
                    The "Argument exception" indicates that you are running a Duet+SBC and it is DSF that failed to do the maths. It's likely been fixed in 3.2.x.
                    • garethkyundefined
                      garethky
                      Fixed for me in 3.2_RC2! 😊
                      • garethkyundefined
                        garethky
                        Sorry no, its not totally fixed. It was broken for other parameter and that is fixed in 3.2. the F parameter still returns the same error.
                        • chrishammundefined
                          chrishamm administrators
                          Thanks for reporting this problem, I'll fix it in the next version.
                          Duet software engineer
