    Please: need to update DWC
    Firmware installation
    770
    • deonholtundefined
      deonholt @Veti
      @Veti do I need to switch off and back on after uploading the file? I just uploaded the file and all were extracted 100%. The page then went completely empty ... I even refreshed the page ... no difference. I don't want to switch off and back on before you giving me the green light.
      • Vetiundefined
        Veti @deonholt
        @deonholt
        try a different browser.
        if that works you need to clear the cache
        deonholtundefined 2 Replies Last reply Reply Quote 1
        • deonholtundefined
          deonholt @Veti
          @Veti great. Worked first shot. Thanks again.
          • deonholtundefined
            deonholt @Veti
            @Veti I unfortunately need to change my reply to: "It worked once but not again". Anything I can try. I cannot even access it from my phone or tablet. Page remains empty. I don't get an error message ... only empty page.
            The wifi seems ok. I could start a single layer square which is printing now. Page remains empty.
            Any other advice will be most welcome. At the moment I am stuck with an empty page.
            If needed, I can access the printer through a USB cable with my Laptop.
            • Vetiundefined
              Veti
              what url are you accessing?
              can you try in incognito mode?
              deonholtundefined 1 Reply Last reply Reply Quote 0
              • deonholtundefined
                deonholt @Veti
                @Veti I'm using the printer's IP address. I can successfully ping it and it is also listed as a connected device on router UI.
                I tried with Edge, Firefox & Chrome, normal and private/incognito mode and in all instances just a blank page.
                I have also switch off and back on the printer a couple of times.
                • Vetiundefined
                  Veti
                  can you type in the url ip/reprap.htm
                  • deonholtundefined
                    deonholt @Veti
                    @Veti How did you know that? You're a genius. Thanks for sticking with me. I don't mind having it like this, but what did not happen or happen? I want to learn.
                    It doesn't look like it installed the file:
                    Firmware Version: 2.05.1 (2020-02-09b1)
                    WiFi Server Version: 1.23
                    Web Interface Version: 1.22.6
                    • Vetiundefined
                      Veti
                      no the reprap.htm will go back to version 1
                      can you try the release from here
                      https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                      deonholtundefined 1 Reply Last reply Reply Quote 1
                      • deonholtundefined
                        deonholt @Veti
                        @Veti
                        Ok, thanks. I have just loaded the file again under ip/reprap.htm
                        Nothing seemed different. I tried again to load the page but only with IP. And it refreshed to what seems to be the updated DWC.
                        It looks a whole lot different and will have to learn the new layout ... but I like it.
                        Thank you so much again for your help. Much appreciated.
                        • deonholtundefined
                          deonholt
                          It says:
                          Duet Web Control 2.0.7
                          I'm so happy.
                          • Vetiundefined
                            Veti
                            @deonholt said in Please: need to update DWC:
                            there will not be an update to version 2
                            so you might consider going to rrf3, but that is a bit more as the config changes.
                            • deonholtundefined
                              deonholt @Veti
                              @Veti
                              Yes, I have learned that. I am not comfortable doing it myself at this stage. Will do it later some time.
                              Thanks again. You have been a great help. The think I like for now the most is that I can change the baby-steps' increments.
