    Duet3 Mini5 crashes connected serial terminals (Mac OS)
    • jchodakowskiundefined
      jchodakowski
      I don't have a direct 1:1 action->result yet, just something that occurs intermittently.
      When uploading firmware via DWC, any connected serial terminal application (Pronterface, SerialTools) will crash with a verbose stack/IO error related to the app (so, not especially informative). This behavior is inconsistent and I've been trying to update to a non-beta 3.2 firmware to eliminate this as a cause but have been unable to (see posting in firmware).
      It's not a fatal problem, subsequent application start and connection will succeed. Since the HW is new, seemed worth reporting. Let me know if I can collect more data.
        When you do a firmware update, RRF sends a message to the USB port, then closes it. It's up to the serial terminal application how it responds to this. YAT is well-behaved in this situation, although it has problems when the PC is put to sleep and woken up.
          A Former User
          picocom (or was it minicom) is well behaved on the other side of the MS fence (i.e. it automatically reconnects when the serial device is removed and reconnected)
            I haven't noticed that with SerialTools on MacOS Catalina. What version of macos are you running?
