    Duet3 Mini 3.2 firmware update fails, maybe?
    Firmware installation
    8
    35
    1.3k
      Phaedrux Moderator @fcwilt
      @fcwilt Yeah only that one bin file is wrong. The rest are the IAP (in app programming) files required for writing the firmware.
      I think there may still be a problem with the zip file.
      Can you download this file and upload it? This should be the right one. This is the loose firmware file included in the release for 3.2.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet3Firmware_Mini5plus.uf2
      When I compare that file to the uf2 file from the zip file I see they are different, so I suspect that the wrong uf2 file was included. I'll see about getting that correct if that is in fact the case.
      BTW what beta version does it show?
      • fcwiltundefined
        fcwilt
        @Phaedrux said in Duet3 Mini 3.2 firmware update fails, maybe?:
        I downloaded the UF2 file, uploaded it to the Duet, all seemed good.
        Still reporting beta though. The date shown is 2020-11-15.
        It is also reporting Duet WiFi Server 1.25 and DWC 3.2.0
          What does the M115 report?
          • fcwiltundefined
            fcwilt @Phaedrux
            @Phaedrux
            In it's entirety:
            FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-11-15
              Can you try including this IAP file from RC1 and try again?
              Duet3_SDiap32_Mini5plus.bin
                Also, I've just realized that the mini5+ firmware uf2 from the zip file is actually for 3.3 alpha. that's why it was different. Not sure yet if that was intentional or if it matters, but I just uploaded the full zip just now and that's the version it reports.
                • fcwiltundefined
                  fcwilt @Phaedrux
                  @Phaedrux Do I need a different UF2 file?
                    @fcwilt I don't think so. But I'm not 100% sure. I went through the same process the other night when 3.2 final came out. I think I was on beta 4 though, and then RC1 and RC2 before going to 3.2 final.
                    I don't have any of the files from the betas, just RC1, 2 and 3.2 final. The beta releases have all been archived.
                    What files do you have in your /sys folder now?
                    The IAP files did go through a renaming from SDiap to SDiap32, so you maybe are missing SDiap? I know they can be renamed in certain cases because there were no changes other than renaming, but I'm not certain of the versions for that.
                    I have to run for a bit, but will check back later.
                    • fcwiltundefined
                      fcwilt @Phaedrux
                      @Phaedrux Files in SYS
                        Phaedrux Moderator @Phaedrux
                        So with this bin file are you able to update with the uf2 from the 3.2 final release?
                        • fcwiltundefined
                          fcwilt
                          If I try to use the SDiap32 version of the file WITHOUT the SDapi version I get that error message about the missing file.
                          I renamed the file from SDiap32 to SDiap and tried again.
                          Now I have 3.3. alpha being reported.
                          This is fun.
                            So now if you upload the full zip file does it update correctly? At that point it should be good to go for future releases.
                            Things always get a bit tricky with beta releases and shifting IAP files.
                            fcwiltundefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              Do you mean go from 3.3 ALPHA back to 3.2 RELEASE?
                              I don't know - I will try.
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                @Phaedrux
                                No change. M115:
                                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3alpha ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-01-05
                                Is it the IAP BIN file or the UF2 file that has the version information?
                                  I just meant upload the whole zip to see if it works complain or change anything. I would expect it to stay at 3.3alpha
                                  • fcwiltundefined
                                    fcwilt @Phaedrux
                                    No it worked without error but stayed at 3.3 alpha.
                                    Anyway to get back to 3.2 release?
                                      @fcwilt said in Duet3 Mini 3.2 firmware update fails, maybe?:
                                      I think the 3.3 alpha should be fine, but this is the loose firmware file included in the release for 3.2.
                                        A Former User @fcwilt
                                        They're given unique names so they can co-exist; is the version that goes with the currently running firmware that is requested when up/down-grading.
                                        If you go back and forth, you might need more than one version, which is only possible if they have different names.
                                        • Vetiundefined
                                          Veti
                                          @bearer said in Duet3 Mini 3.2 firmware update fails, maybe?:
                                          SDiap
                                          the version that comes with the original files does not work correctly for upgrading.
                                          see my linked post. dc42 posted a new version that works for normal upgrading.
                                            A Former User @Veti
                                            @Veti said in Duet3 Mini 3.2 firmware update fails, maybe?:
                                            SDiap
                                            not sure how that invalidates saying "don't rename them" and "keep the previous version if going back and forth"
