Error: Heater 0 fault: heater monitor 0 was triggered
Here are the results of the Firmware upgrade:
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
Duet WiFi Server Version: 1.25 -
Try retuning the bed heater after updating the firmware.
Note that firmware 3.2 has a new PID tuning algorithm.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning -
Ok, I will retune the pid for the bed using the autotune now, I was trying to get to and maintain a bed temp of 120 degrees C btw.
@dmbgo said in Error: Heater 0 fault: heater monitor 0 was triggered:
Well you've set your bed temp limit to 120c. So as the error says, your heater monitor was triggered.
If that's a temp you intend to use frequently you should you that temp to tune to, and change the M143 command to a higher temperature to allow for over shoot. 130 maybe.
Thanks Phaedrux, I will change the Temp limit for the bed to 135C after it finishes tuning. I'll then try to run a print and let you know.
The tuning is in progress... -
Here is my updated config.g. Tuning is still in progress, so I haven't restarted the board to apply the new settings yet.
; generated by RepRapFirmware Configuration Tool v3.2.0 on Sat Jan 02 2021 15:54:53 GMT+1100 (Australian Eastern Daylight Time); General preferences
M550 P"Black Widow" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z1000.00 E420.00 ; set steps per mm (z was 4000)
M208 X370 Y250 Z300 S0 ; set axis maxima
M208 X-205:165 Y-140:110 ; set axis limits; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end (or high end?) on X via pin xstop (was M574 X1 S0 P"xstop")
M574 Y1 S1 P"!ystop" ; configure active-high or low? endstop for low end on Y via pin ystop (S0 = no endstop) ;if you are using RepRapFirmware 3 then you will need to use S1 but invert the polarity by putting a ! character at the start of the pin name in the M574 command
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X48 Y-18 Z3.8 ; set Z probe trigger value, offset and trigger height
M557 X15:355 Y15:235 S20 ; define mesh grid; Heaters
M143 H0 S135 ; set temperature limit for heater 0 to 135C
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
M106 P0 T45 H1 ; set fan 0 value. Thermostatic control is turned on; Tools
M563 P0 S"Extruder" D0 H1 F0 ; define tool 0;
M575 P1 S1 B57600 ; enable support for PanelDueM501 ; load values stored in config-override.g
How long does the new tuning algorithm take? It seems to be hovering around 80C atm,. I told it to tune to 120C.
Should I reset and start the tuning again? It still says it is running.
1/14/2021, 11:51:57 AM Upload of config.g successful after 0s
1/14/2021, 11:50:19 AM Upload of config.g successful after 0s
1/14/2021, 11:40:18 AM Auto tune starting phase 1, heater on
1/14/2021, 11:40:13 AM M303 H0 P0.4 S119
Auto tuning heater 0 using target temperature 119.0°C and PWM 0.40 - do not leave printer unattended -
I grew impatient and reset the printer. I then sent the following:
M303 H0 P0.4 S120I'll wait without changing anything now.....
Hmmm, I seem to have this error when doing the Autotune:
1/14/2021, 12:34:32 PM Auto tune cancelled because target temperature was not reached
1/14/2021, 12:04:32 PM Auto tune starting phase 1, heater on
1/14/2021, 12:04:26 PMI'm not sure if it is related or not to my original issue. I'll try turning the bed heater on now with a 120C target.
No issues getting to, or maintaing the bed at 110C, which is what I ended up commanding the printer to do. I'll try printing something now and see if there is any change in the errors after the FW upgrade.
This is the heater graph now, while the printer is printing a calibration cube.
As you can see the temperatures are fairly constant according to the graph, which is how they were before.
The big difference this time, is that the bed heater error hasn't occured (yet). -
It can take a long time.
M303 H0 P0.4 S120
Why did you reduce the PWM factor so much?
1/14/2021, 12:04:26 PMAutotune didn't work, the second attempt at autotune led to the error above, however printing with the heatbed PID settings from an earlier firmware version that did successfully autotune, I have not experienced anymore heatbed errors.
Given that the errors were very constant, I think that it might be fixed.
Thanks! -
Oh and the reduction of the PWM factor was from the example at:
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
Yes the previous tuned values should still be valid.
I would try tuning again with full power to see if it has better luck hitting the commanded temp.
It's just an example of how the power factor can be used. Normally you'd want to tune at full power. I'm going to change that example. Actually I don't see that example at all in that tuning link, but I did find it in the M303 entry in the gcode wiki and have changed it to use 100%. The only times you'd want to use that is with an overpowered heater that is throwing "heating too fast" errors.
That makes sense Phaedrux. I was wondering why it was 40%. Given that the errors seem to have gone after the FW update, and the bed is stable, do you see any reason not to move on?
