    New experimental firmware 1.19beta8
    Firmware installation
    10
    28
    4.1k
    • Kulitorumundefined
      Kulitorum
      Testing IDEX on beta8 and when I change tool, the "new" tool moves to the position of the old tool after running my post.g code.
      This means that the heads collide and the new tool looses position.
      I could post all my config, but I don't want to clutter the post. Let me know what parts you are interested in.
      //M122 while printing single head:
      Used output buffers: 3 of 32 (15 max)
      RepRapFirmware for Duet WiFi version 1.19beta8 running on Duet WiFi 1.0 + DueX5
      Board ID: 08DAM-999TL-MQ4S8-6JKF0-3SN6N-1NBHW
      Static ram used: 20900
      Dynamic ram used: 96620
      Recycled dynamic ram: 1264
      Stack ram used: 1304 current, 9016 maximum
      Never used ram: 3272
      Last reset 00:22:04 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 3196 bytes (slot 2)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 0.0ms
      MCU temperature: min 36.9, current 37.2, max 37.5
      Supply voltage: min 19.4, current 20.0, max 20.3, under voltage events: 0, over voltage events: 0
      Expansion motor(s) stall indication: no
      Driver 0: stalled
      Driver 1: ok
      Driver 2: stalled open-load-B
      Driver 3: stalled standstill
      Driver 4: standstill
      Driver 5: ok
      Driver 6: standstill
      Driver 7: standstill
      Driver 8: standstill
      Driver 9: standstill
      Date/time: 2017-07-03 21:40:47
      Slowest main loop (seconds): 0.005737; fastest: 0.000000
      MaxReps: 4, StepErrors: 0, MaxWait: 1ms, Underruns: 0, 0
      Scheduled moves: 18501, completed moves: 18472
      Bed compensation in use: mesh
      Probe change coordinates:
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.2
      Segments left: 1
      Stack records: 3 allocated, 0 in use
      Movement lock held by file
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X127.370 Y125.110 E3.3039" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19beta8
      WiFi MAC address a0:20:a6:16:e7:72
      WiFi Vcc 3.08, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 40024
      WiFi IP address 192.168.1.180
      WiFi signal strength -63db
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        @Kulitorum, don't you have your tfree#.g files set up to park the old tool?
          Kulitorum
          ; Put G/M Codes in here to run when Tool 0 is freed
          M83  ; relative extruder movement
          G91 ; relative axis movement
          G1 E-3 Z3 F3600 ; retract 2mm and lift head
          G90  ; absolute axis movement
          G1 S2 X-27 F42000 ; park the X carriage at -27mm
          G1 E3 F3600 ; unretract 3mm
          M82 ; absolute extruder movement
            Kulitorum
            Post#.g:
            M116 P0  ; wait for tool 0 heaters to reach operating temperature
            G1 E2 F3600  ; extrude 2mm
            G1 Z-3 F500  ; up 3mm
            ;G1 R1 F42000 ; Goto where we left off
              Ok, so if the head is moving to the position of the old tool, which position is that? The position before it ran tfree0.g, or something else?
                Kulitorum
                It moves to the park position of the old head.
                PS: Can you change the 60 sec between posts? - Seeing this for the third time today….. Also the 30 sec between searches is annoying - if you did not find what you were looking for, you can't re-search for 30 secs.
                  I can guess what might be happening. For now I suggest you try starting the tpost file with a G1 S2 command to move the new year to its park position. There should be no actual movement because it should already be parked, but that command should update the desired X coordinate.
                  In the latest beta you should be able to use G1 R2 at the end of tpost to move the head to the position of the old tool before the tool change.
                  • Whitewolfundefined
                    Whitewolf
                    Clicking upload print disconnects me randomly on this build. and it takes a few to reconnect.
                    • mattbenimbleundefined
                      mattbenimble
                      @dc42 . on the latest build G30 S-1 does not flash a value anymore. Is this a change that i missed?
                        G30 S-1 should still report the trigger height to the device that you sent the command from.
                          Whitewolf
                          DC42,
                          I am at a loss here on what to do, you have not responded to my comments in a few days.
                          It makes it pretty hard to do anything
                            If everything is slow and laggy then first establish whether the PC or the Duet is to blame. Reboot both, connect to the Duet from the PC with nothing else running on the PC and see whether it is still slow and laggy. If yes then you have hit an issue that nobody else has reported afair and I suggest you revert to 1.18.2. If it remains slow and laggy then suspect an IP address conflict.
                            You can configure the number of reconnect retries in DWC.
                            HTH David
                              deckingman
                              David,
                              I've been meaning to say thanks for the thermostatic fan hysteresis which works like a charm.
