    New experimental firmware 1.19beta8
    Firmware installation
    10
    28
    4.1k
    • whosrdaddyundefined
      whosrdaddy
      actually I have a typo in my config.g, my probe sits 4.25 cm to the right of my nozzle.
      So the correct G31 command is G31 X42.5 Y0 Z0.87 P500
      so taking this into account, I should be able to probe absolute coordinates X0:137.5 and Y0:290, so this means the probe will be at positions X42.5:X200 Y0:290, right?
        It works the other way round. The grid specifies where you want to probe. The lowest X value that the probe can reach will be the minimim X set in your M208 S1 command plus 42.5mm.
        I added the warning messages in the most recent beta, because too many users have been asking why it doesn't probe all the points they asked for.
          whosrdaddy
          Thanks that makes sense.
          It would be nice to mention this in the GCode M557 wiki/Mesh bed compensation wiki as this leads to confusion 😉
          • Whitewolfundefined
            Whitewolf
            I updated from 1.18.1 to 1.19beta8 last night…. running mesh bed compensation completes correctly but does not load the visual after just gives and error about not being able to find the heightmap file.... but I can click view on the file just fine and it opens after.
            Also I have to jump on the bandwagon of people who are constantly disconnected from the DWC. It happens randomly when I click things and if I am away for a few minutes.
            Everything is also very slow and laggy now.... clicking anything there is a lag a pretty large one.... I can probably count 10 to 15 seconds before a jog button click or config file open responds. My printer is currently 5 feet from a high end Asus wireless router
            • Kulitorumundefined
              Kulitorum
              Testing IDEX on beta8 and when I change tool, the "new" tool moves to the position of the old tool after running my post.g code.
              This means that the heads collide and the new tool looses position.
              I could post all my config, but I don't want to clutter the post. Let me know what parts you are interested in.
              //M122 while printing single head:
              Used output buffers: 3 of 32 (15 max)
              RepRapFirmware for Duet WiFi version 1.19beta8 running on Duet WiFi 1.0 + DueX5
              Board ID: 08DAM-999TL-MQ4S8-6JKF0-3SN6N-1NBHW
              Static ram used: 20900
              Dynamic ram used: 96620
              Recycled dynamic ram: 1264
              Stack ram used: 1304 current, 9016 maximum
              Never used ram: 3272
              Last reset 00:22:04 ago, cause: power up
              Last software reset reason: User, spinning module GCodes, available RAM 3196 bytes (slot 2)
              Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 9
              SD card longest block write time: 0.0ms
              MCU temperature: min 36.9, current 37.2, max 37.5
              Supply voltage: min 19.4, current 20.0, max 20.3, under voltage events: 0, over voltage events: 0
              Expansion motor(s) stall indication: no
              Driver 0: stalled
              Driver 1: ok
              Driver 2: stalled open-load-B
              Driver 3: stalled standstill
              Driver 4: standstill
              Driver 5: ok
              Driver 6: standstill
              Driver 7: standstill
              Driver 8: standstill
              Driver 9: standstill
              Date/time: 2017-07-03 21:40:47
              Slowest main loop (seconds): 0.005737; fastest: 0.000000
              MaxReps: 4, StepErrors: 0, MaxWait: 1ms, Underruns: 0, 0
              Scheduled moves: 18501, completed moves: 18472
              Bed compensation in use: mesh
              Probe change coordinates:
              Bed heater = 0, chamber heater = -1
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.2
              Segments left: 1
              Stack records: 3 allocated, 0 in use
              Movement lock held by file
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is doing "G1 X127.370 Y125.110 E3.3039" in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              Network state is running
              WiFi firmware version 1.19beta8
              WiFi MAC address a0:20:a6:16:e7:72
              WiFi Vcc 3.08, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 40024
              WiFi IP address 192.168.1.180
              WiFi signal strength -63db
              HTTP sessions: 1 of 8
              Socket states: 2 0 0 0 0 0 0 0
              Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                @Kulitorum, don't you have your tfree#.g files set up to park the old tool?
                  Kulitorum
                  ; Put G/M Codes in here to run when Tool 0 is freed
                  M83  ; relative extruder movement
                  G91 ; relative axis movement
                  G1 E-3 Z3 F3600 ; retract 2mm and lift head
                  G90  ; absolute axis movement
                  G1 S2 X-27 F42000 ; park the X carriage at -27mm
                  G1 E3 F3600 ; unretract 3mm
                  M82 ; absolute extruder movement
                    Kulitorum
                    Post#.g:
                    M116 P0  ; wait for tool 0 heaters to reach operating temperature
                    G1 E2 F3600  ; extrude 2mm
                    G1 Z-3 F500  ; up 3mm
                    ;G1 R1 F42000 ; Goto where we left off
                      Ok, so if the head is moving to the position of the old tool, which position is that? The position before it ran tfree0.g, or something else?
                        Kulitorum
                        It moves to the park position of the old head.
                        PS: Can you change the 60 sec between posts? - Seeing this for the third time today….. Also the 30 sec between searches is annoying - if you did not find what you were looking for, you can't re-search for 30 secs.
                          I can guess what might be happening. For now I suggest you try starting the tpost file with a G1 S2 command to move the new year to its park position. There should be no actual movement because it should already be parked, but that command should update the desired X coordinate.
                          In the latest beta you should be able to use G1 R2 at the end of tpost to move the head to the position of the old tool before the tool change.
                            Whitewolf
                            Clicking upload print disconnects me randomly on this build. and it takes a few to reconnect.
                            • mattbenimbleundefined
                              mattbenimble
                              @dc42 . on the latest build G30 S-1 does not flash a value anymore. Is this a change that i missed?
                                G30 S-1 should still report the trigger height to the device that you sent the command from.
                                  Whitewolf
                                  DC42,
                                  I am at a loss here on what to do, you have not responded to my comments in a few days.
                                  It makes it pretty hard to do anything
                                    If everything is slow and laggy then first establish whether the PC or the Duet is to blame. Reboot both, connect to the Duet from the PC with nothing else running on the PC and see whether it is still slow and laggy. If yes then you have hit an issue that nobody else has reported afair and I suggest you revert to 1.18.2. If it remains slow and laggy then suspect an IP address conflict.
                                    You can configure the number of reconnect retries in DWC.
                                    HTH David
                                      deckingman
                                      David,
                                      I've been meaning to say thanks for the thermostatic fan hysteresis which works like a charm.
