    Duet 3 mini Menu Files
    Firmware installation
    683
      I'll have to double check. I use a Paneldue so I hadn't been using the stock display, but as part of the mini5 guide I'll get it up and running.
      • Vetiundefined
        Veti
        install this example menu in the menu directory on the sd card
        https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files/releases
          dc42 administrators @lodger
          @lodger, please check that you are running DWC 3.2 and RRF 3.2. Also that you have enabled the display using an appropriate M918 command in config.g.
          • lodgerundefined
            lodger
            Mornings,
            Right i have double checked i am running up to date RFF and DWC i have even update the wifi server . I have all the menu files correct in the Menu Directory.
            I also have:
            M918 P1 E4 F2000000 ; configure direct-connect display
            In my config.g
            So i am a little lost now.
            I dont know if it help but my Diagnostic File say " LCD is idle in state(s) 0"
              @lodger said in Duet 3 mini Menu Files:
              But DWC dose not have a menu section
              It's called "Display and should be just above "Filaments".
              • lodgerundefined
                lodger
                Having re done a firmware update this morning I now have display section showing all my files correct..
                Running a M918 in the terminal reposts correctly.
                So now i am thinking it is a wiring issue. I will look more into it later . The boss is telling me i have to do house work first... : (
                • lodgerundefined
                  lodger
                  Ok Have been playing a bit . And i have the FYSETC Mini working fine . but not the ender 3 display.
                  I am guessing the Enders display is not ST7567 controller.
                    Correct, the Ender 3 uses a ST7920-based controller, which is P1 in he M918 command, not P2.
                    Almost all the ST7920-based controllers I have seen are designed to work with 5V signal levels, although I have heard of similar displays working with 3.3v signal levels at reduced speed on other controller boards.
                    A final complication is that the pinout is different from the Mini 12864, so you would need to make up a special cable, or else modify the display.
                    • lodgerundefined
                      lodger
                      Thanks Dave.
                      I am liking the mini Lcd so will print some thing up and use that.
                      I will sit down next week when i am at work and bored to figure out a lead to get the Enders Display working. If it will work being 5v. If not i will try and find a replacement.
                      I think a lot of folks will want this board on creality marchines.
                        Phaedrux Moderator @Veti
                        @Veti Had you gotten the Ender 3 display to work with the Mini5+?
                        • Vetiundefined
                          Veti
                          i have not tried it.
                          • Vetiundefined
                            Veti
                            just tried connect the ender 3 one and a standard 12864.
                            all i get is a high pitched noise from the buzzer. cant test more or my neightbours will be annoyed.
                            no display output.
                              same here. 😑
                              • lodgerundefined
                                lodger
                                I did connect it up correct using jumper wires to get the correct pin outs .
                                But still have no success. I did not get much time to play more as the printer is at work. and i was busy.
                                I do think it is 5v issue but i will try mess more next week. as sometimes you can see some txt and the screen flashes on and off i bit.
                                On a side note i have found a larger ST7567 controller based RGB Screen .looks the same layout and size of the Enders. I have ordered it and will report back if that works.
                                  jay_s_uk @lodger
                                  @lodger try reducing the SPI speed. To something like F100000 (add that to the M918)
                                    Here are some notes I made when I was looking at this:
                                    • EXP2 is the same on the Mini and the ST7920 display but reversed between them.
                                    • EXP1 is also reversed but has the following additional changes
                                    • The 3 Mini has LCD_A0 where the RRD display expects CS. This is handled in firmware - the firmware uses A0 as CS when a type 1 display is configured in M918.
                                    • The Mini has LCD_RST (which the Mini just ties high through a pullup resistor) where the type 1 display expects SCLK
                                    • The Mini has the CS pin where the type 1 display expects MOSI
                                    • ENCA and ENCB are also swapped, but that doesn't matter, you can change the direction in the M918 command
                                    So I think the easiest way to drive the display would be:
                                    • Reverse the connectors at one end of each cable
                                    • Cut the conductors in the EXP1 ribbon cable that carry LCD_RST and SPI2_CS2 from the Mini to wrong pins on the display
                                    • On the display add links to carry MOSI and SCK from the EXP2 connector to the correct pins on the EXP1 connector
                                    I have not tested this.
