    Mirror image and homing on x axis
    935
    • fcwiltundefined
      fcwilt @ortondale
      @ortondale said in Mirror image and homing on x axis:
      @fcwilt Hi Frederick
      My sensors are in the same position as your printer, it’s the X=0 position on my printer that needs flipping so the axis is not mirrored. You have X=0 in the centre of your bed, the right side of the X=0 will read a plus movement and the left side will read minus. My printer is the opposite and I cannot work out how to reverse it.
      Did you change the M569 settings for the axis?
      ortondaleundefined 1 Reply Last reply Reply Quote 0
      • ortondaleundefined
        ortondale @fcwilt
        @fcwilt Do you mean M569 don’t think M596 is in the code?
        Yes, changed 0P and 1P around combination of forwards and backwards with no result.
        I’m well into my 70,s and the minds not as sharp as it used to be so I might be missing an obvious error in the set up. I will just have to remember to keep flipping the x axis at the slicing stage until I can find the problem. Thanks for your time, much appreciated.
        Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
        • Vetiundefined
          Veti @ortondale
          you really need to read the page i linked.
            ortondale @Veti
            @Veti Been over the linked page but will revisit again to make sure, might have to get back to you if I can’t figure it out
            • fcwiltundefined
              fcwilt @ortondale
              Sorry - a typo - yes M569.
              So you tried M569 P0 S0?
                ortondale @fcwilt
                @fcwilt Yes, it created a diagonal movement to the right front
                • fcwiltundefined
                  fcwilt @ortondale
                  My bad - I missed that you have a CoreXY machine.
                  In that case it gets a bit tricky.
                  On my Mark Forged style printer I had to use M669 (instead of M667) with the appropriate parameters to get the motors to move correctly.
                  The documentation for M669 discusses how to set the parameters but in my case I determined them by trial and error.
                  • Vetiundefined
                    Veti
                    If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
                      ortondale @Veti
                      @Veti The head moved diagonal to right front corner X=0 Y=0 with P0 S0
                      P0 S1 is the line I’m running which gives the mirror
                      • Vetiundefined
                        Veti
                        have you swapped the motor connections?
                        • fcwiltundefined
                          fcwilt @Veti
                          @Veti said in Mirror image and homing on x axis:
                          That would work as well or determine the correcting settings for M669 and use it in place of M667.
                            https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue?_=1610937338221
                              ortondale
                              Problem Solved
                              Switched motor plugs around on X and Y
                              Reversed motor direction
                              Changed end stop to X1
                              Home X axis changed from G1 H1 X255 to G1 H1 X-255
                              Go back a few mm changed from X-5 to X5
                              Reset probe point and mesh bed configuration
                              All is well
                              Big thanks to Veti, fcwilt and Phaedrux (moderator) for the advice pointing me in the right direction. Great Forum
                              • fcwiltundefined
                                fcwilt @ortondale
                                @ortondale Very glad to see you got it sorted - good work.
